| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
Does anyone own this bridge?
I'd like to do some questions on this instrument. Or better have the manual. It looks like a good bridge and sold in a good price on e-bay. I'm thinking seriously to buy one............. |
#2 |
Account Disabled
Noone owns a Marconi bridge?
#3 |
I do. It is an excellent bridge. What do you need to know?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
Account Disabled
wow I have posted this subject many days ago. Almost I forgot it!
And............. I'm missing a long time from the boards.But I remember you from the "tubes" section. I don't have a bridge and there are a lot of times that I'd like to measure capacitance and impedance. I'd like to know if it can measure choke and primary impedance of an OPT. But my problem is to measure a choke, say at 50Hz and 200mA an OPT at 20Hz and 50mA. Also does it apply any high voltage to the measured coil? Not a problem if it needs an external signal generator or current source. It will be helpfull if you can send me a copy of the Marconi's manual..... ![]() Thanks |
#5 |
You're very kind.
The TF2700 can measure: Primary inductance of an output transformer. Inductance of a choke with DC applied but it needs an external constant current source to apply the DC. It is also best if you give it an external source of AC so that it can measure smoothing chokes at 100Hz. Air-cored crossover chokes (best done at 20kHz). And it's very good for measuring capacitors (not so good for electrolytics). There's really rather a lot of the manual, and scanning it would be a lot of work; just make sure you get a manual when you buy the bridge.
#6 |
Account Disabled
yup the correct name is inductance!sorry but I'm not good with english. So, with an external cs you can apply the desired mA. And with an external source of AC you mean a signal generator? What about voltage? Can you apply an external high voltage to the choke? |
#7 |
I'm not sure why you'd want to apply a high voltage to the choke (other than to check for breakdown) - it's a current dependent device.
Don't worry about your English, my French would have a Frenchman in tears.
#8 |
Account Disabled
Isn't better to measure it under conditions similar to which the choke is used.
I read this to Radiotron D Handbook..... Do you have it? (pg250) It says that "the value of inductance depends to a marked degree on the ac flux density in the core and also on any dc flux set up in the core by direct currents in the windings" |
#9 |
You are absolutely right - a test should as closely as possible replicate the conditions of use. And as RDH4 says, the flux in the core of an inductor markedly changes the inductance, so you need to be able to vary that. But that's down to current not voltage. Here's one I measured earlier...
#10 |
Account Disabled
I know that inductance changes with different applied currents but....................
Can you do a test with a constant current and a variable applied voltage? Just to see the differences.If there are any! I believe you but I'm just wondering what happans if the voltage is variable. I don't have the instruments to check it..... I thing I'll hit a Marconi TF2700 bridge! I like the old style design too!
| Reopening an unfinished debate: Dual bridge vs. Single Bridge | xiphmont | Chip Amps | 15 | 26th February 2008 07:22 PM |
| four high-power iron-core chokes 3mH | cocolino | Swap Meet | 0 | 14th May 2007 12:42 AM |
| Looking for informations on Marconi TF2331 Distortion Factor Analyser | bembel | Tubes / Valves | 12 | 27th November 2006 03:46 PM |
| Plate chokes & Power chokes | JC951t | Tubes / Valves | 3 | 19th October 2006 03:18 PM |
| regarding to the design of iron-cored inductors (chokes) | metebalci | Tubes / Valves | 3 | 14th August 2004 12:58 AM |
| Page generated in 0.12203 seconds (80.01% PHP - 19.99% MySQL) with 11 queries |
