Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th March 2007, 03:31 AM   #1
Tenson is offline Tenson  United Kingdom
Default DC Step-up IC
I was wondering if anyone knew of any really simple to use IC's that could step-up a 3.3v to about 8v and handle around 1a of current or more?
The best I can find is the LM2623AMM, but it needs a fair few external components. I would like something as simple as possible to do the job if there is such a thing?!
Suggestions appreciated. Even if you just tell me such a thing doesn't exist
I want it because I have an unregulated 3.3v line that I want to regulate. So I need to step it up and then regulate it back to 3.3v lol. No other way I can see of doing it, unless there is some wonderful regulator that will manage to regulate 3.3v and not drop more than o.3v?
Old 15th March 2007, 01:26 PM   #2
theAnonymous1's Avatar
Why would you want to step up the voltage with a DC-DC just to regulate it back down with a linear reg? Just use a regulated DC-DC with 3.3v output.
http://datasheets.maxim-ic.com/en/ds...0-MAX1760H.pdf
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 15th March 2007, 03:30 PM   #3
Since it is designed to 'step-up', will it not dislike having the same voltage on the input as I ask it to output?
Thanks for the link though. I guess it will work just fine
Step-by-step ambitious first project! Suggestions? ledhed2222 Multi-Way 7 13th August 2009 03:51 AM
Step-by-step guide to building a speaker Richy Multi-Way 5 5th August 2008 12:48 AM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
how to make spherical wood horns, step by step angeloitacare Multi-Way 0 29th May 2007 01:50 AM
LM3886 & LM3876 Step-by-step P2P Guides?? zenon Chip Amps 11 18th November 2006 03:16 PM
Page generated in 0.08216 seconds (69.96% PHP - 30.04% MySQL) with 10 queries
