Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th March 2007, 05:08 PM   #1
Question Multiple speakers on audio output line
Is there some sort of product that would allow you to connect a wire from the headphone port of a computer or cd player, etc. and have multiple ports for connecting other jacks (i.e. multiple speakers from the same source. I need some sort of setup like this. Basic equipment connected to basic speakers using basic wires. It would be some sort of go-between box.
I've drawn (very poorly) a mockup. It's the attatched file. Please help me.
Old 12th March 2007, 08:28 AM   #2
No, there isn't a device to do what you show.
There are solutions but all of them need at least a power amplifier.
You can use 70V or 100V transformer coupled speakers but these are usually low quality and designed for public address rather than domestic audio distribution.
Where are these speakers going?
regards Andrew T.
Old 16th March 2007, 11:39 PM   #3
The speakers don't need to be very high quality. They'll be in a haunted house. (By the way, I'm kind of a newbie at thos stuff)
Old 16th March 2007, 11:48 PM   #4
Speakerholic
Cal Weldon's Avatar
So we have until October to figure this out?
You can do it with a regular stereo amplifier/receiver provided you want all the speakers at the same volume and you run them in groups of series and parallel to maintain your overall impedance. Mind you, it makes for a lot of wire so using the 70V public address method Andrew mentioned makes sense.
How far away are they going to be from the amp and how many speakers in total?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 18th March 2007, 03:16 AM   #5
The distance may vary. In some cases, it may be 2-6 speaker sets for a certain segment, and in others, it may be many speakers linked together to provide the master volume for the house. Also, because of this, the distance from the amp may vary. (I know I'm not being very helpful right now) I would have more than one of these systems, i.e. providing audio for the whole haunted house and tailored segments for a certain area, etc.
Old 18th March 2007, 10:48 AM   #6
dangus is offline dangus  Canada
Maybe you could use a little FM transmitter, and put FM radios where you need speakers?
Old 18th March 2007, 01:09 PM   #7
That might work in some areas, but many may be too close and have signal overlap. That could be one of the methods used, though.
Old 29th March 2007, 09:58 PM   #8
Does anyone know of any other methods that might work effectively, because as I said in the previous post, fm transmitters might work in some areas, but for most of the house, I'll need some other solution. Thanks to all who have helped me so far!
Old 30th March 2007, 09:57 PM   #9
mazurek is offline mazurek  United States
My friend is using a distribution amplifier, and partsexpress impedence matching volume controls for his whole house audio
Old 10th April 2007, 10:39 PM   #10
Where would I find something like that? (Thank you very much for the suggestion, it's just that I'm not much of an audio person, so I'm not familiar with the terms or equipment)
What about multiple small speakers? gruni Subwoofers 24 24th March 2009 07:31 PM
Is there a program which can switch the audio output between left/right speakers? coooljono Multi-Way 0 15th January 2006 09:12 AM
Multiple speakers rfarn Everything Else 1 4th November 2005 03:35 AM
Reducing Audio Line Output? freezz Everything Else 12 29th June 2005 11:48 AM
Line Array / multiple driver crossover design awdtalon92 Multi-Way 2 26th March 2004 07:49 PM
Page generated in 0.11280 seconds (79.60% PHP - 20.40% MySQL) with 11 queries
