| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hi there, i have tried to make some of my own RCA plugs but i think i have mucked it up. how many wires should come out of each RCA plug? i have only one going to a connector. do i need another one to go to the metal cap? Because there's a connector for a wire on the cap
thanks! |
#2 |
One signal conductor + ground = 2 wires. You should use a shielded cable with the shield or the shield's drain wire connected to the metal cap, and the inner conductor connected to the pin of the connector.
#3 |
for ALL electrical connections you need a flow and return. The RCA connector uses the pin and one wire as the flow and uses the barrel and the second wire as the return. The second wire can instead be the shield of the co-axial cable.
regards Andrew T. |
#4 |
thanks for your help. i have now made the cables and they are great.
#5 |
Any photos of the plugs?
| PPI plugs - the old flat speaker plugs | jol50 | Car Audio | 0 | 21st January 2009 09:28 PM |
| Pin Plugs - How ? | EdT | Multi-Way | 5 | 8th February 2007 04:16 PM |
| Best RCA Plugs | taccodude | Parts | 23 | 23rd August 2006 06:37 PM |
| RCA Plugs | Tomo | Everything Else | 15 | 22nd October 2002 09:03 PM |
| Page generated in 0.06110 seconds (82.61% PHP - 17.39% MySQL) with 10 queries |
