diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   ***NAME this part... (http://www.diyaudio.com/forums/parts/97735-name.html)
profuse 9th March 2007 04:16 AM
***NAME this tan rectangular part, the deformed one.
The card is from a CRT projection TV mitsubishi.
Not too sure if that part suppose to look like that or it looks like it about to explode.
Anyone know what it is and know where to purchase one, plz lmk.
http://i85.photobucket.com/albums/k7...V/104_5218.jpg
http://i85.photobucket.com/albums/k7...V/104_5212.jpg
http://i85.photobucket.com/albums/k7...V/104_5215.jpg
I_Forgot 9th March 2007 04:32 AM
It is probably some sort of hybrid circuit and is probably supposed to look that way.
The large bumps are likely some inductors or large capacitors. The whole circuit is potted to hide or protect it.
If it isn't cracked or burned, it is probably OK.
I_F
profuse 9th March 2007 05:05 AM
there is a melting residue under the hump. hybrid? why would they even design it like it?
phase_accurate 9th March 2007 06:20 AM
Why not ???? :confused:
In the seventies and eighties you could see a lot of hybrids that were looking this way.
I even remember a workmate who "repaired" one of these. Under such a protrusion was a defective transistor (in T092). He simply milled the ceramic material away and soldered a new transistor in place. This was just a provisional solution before he got the original hybrid as spare part.
Charles
Elvee 9th March 2007 07:34 AM
As it is made by TDK, it's probably some sort of filter, or L/C correction network or delay line. As said above, the chances it is defective are very low. Concentrate on active components and chemicals; that's probably where the trouble hides.
LV
radtech 9th March 2007 03:55 PM
Name this part... ok, Howard the Hybrid.
Yeah, they're just little hybrids, generally a ceramic substrate circuit with a few large parts where the bulges are. The 'melting residue' is probably wax, I've seen many that appear to have been dipped in wax, probably to help keep moisture out.
I'd be careful milling any type of ceramic, some of that stuff can be toxic if inhaled.
profuse 9th March 2007 04:25 PM
thanks fellas.
Resources saved on this page: MySQL 18.75%
