Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th March 2007, 02:58 AM   #1
Default 1 output, 3 amps
I would like to triamp my speakers, but only have one output from my preamp. I was wondering if I could just build a simple project with one input and three outputs. Just using some RCA jacks and connecting them together. Is ther anything to consider when doing this?
Old 9th March 2007, 04:14 AM   #2
neutron7's Avatar
If you are using crossover components in the speakers you could do that, you should probably use a buffer though instead of directly splitting the output.
it depends how much the preamp can drive and what the input impedance of your amplifiers are.
if you do not want to use any passive crossover components in the speakers then you would need to put a 3 way active crossover there.
here is a fairly simple one that would use 6 dual or 12 single opamps.
http://sound.westhost.com/project78.htm
Old 5th May 2007, 12:43 AM   #3
How would I add a buffer to this?
Old 5th May 2007, 12:52 PM   #4
XEAGLEKEEPER's Avatar
This would be a better route IMO
http://www.sound.westhost.com/project09.htm
a L/W 24db/octave
will require 2 boards for stereo tri-amping-buffers included,PC boards available---
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 6th May 2007, 01:04 PM   #5
Whin I use this, how do I bypass the internal crossover?
Old 6th May 2007, 03:29 PM   #6
Sonusthree's Avatar
Remove the crossover components from the signal path by connecting the drivers directly to the terminal posts except for the tweeter ............
For the tweeter I recommend adding a series capacitor of at least 5uF (but preferably larger) to protect it from damaging D.C. that may cause you problems. A smaller cap would work but will interfere with your new (active) crossover curve.
You should also check that your mid range and tweeter amps are not putting out any significant D.C. that might damage your drivers when unprotected by a conventional passive crossover.
Martin.
What Solid State Amps with Output Transformer do you know of? Onvinyl Solid State 27 27th April 2010 10:41 PM
Optimus amps - Increasing output DCJuicer Car Audio 17 1st July 2008 05:18 PM
Why older RF amps always blew up with DC in output valterdaw Car Audio 10 18th August 2006 02:15 AM
Using differential amps for output I/V? ezkcdude Digital Source 3 27th April 2006 08:43 PM
Page generated in 0.10233 seconds (70.75% PHP - 29.25% MySQL) with 10 queries
