Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
LED matrix input device, how do they do it?
Old 8th March 2007, 08:42 PM   #1
neutron7 is offline neutron7  Canada
neutron7's Avatar
Default LED matrix input device, how do they do it?
http://cs.nyu.edu/~jhan/ledtouch/index.html
it shows an LED matrix being used as an input device.
i want to make a USB input device using some of these.I have many of them from some LED signs that were thrown out because the cpu boards were toast.
i cant figure out what is actually happening, they say the LED also acts as a light dependant diode, but once the LED is off to measure, where does the light come from to measure?
Old 8th March 2007, 09:46 PM   #2
On Hiatus
SY's Avatar
The on-off time of LEDs is quite fast. If you run them at a lower duty cycle, you can use the "off" time to photodetect. I haven't read the Mims paper, but ambient light might work. Even better (I think) would be to scan, i.e., turn the LEDs off one at a time and use the remaining light of the others as illumination.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th March 2007, 10:15 PM   #3
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
The diodes can operate as emitters and detectors simultaneously. There will be small fluctuations in the voltage across the LED if supplied with a constant current, depending on the amount of light hitting the LED. The light may be from another source, or just light from the LED reflected back to the LED.
Several months ago I saw an article where someone used lit LEDs as an input device to a uC. I think it may have been in Circuit Cellar.
I_F
Old 10th March 2007, 03:41 PM   #4
cpemma is offline cpemma  United Kingdom
http://www.merl.com/publications/TR2003-035/
And some DIY testing here.
LED matrix input device, how do they do it?Hide this!Advertise here!
Help With Amp For B&W Matrix 3's led_zeppelin Solid State 0 9th October 2006 01:14 AM
B&W Matrix 3's led_zeppelin Swap Meet 4 13th July 2004 07:37 PM
B&W Matrix 3's led_zeppelin Multi-Way 0 15th December 2003 12:58 PM
Cartridge amplifier with remote input device jcarr Analogue Source 2 19th March 2003 10:52 AM
To matrix or to not matrix? Trist Subwoofers 8 15th July 2001 08:48 AM
Copyright ©1999-2017 diyAudio
