Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th March 2007, 01:24 PM   #1
Default Switch realization for this idea
I am posting a similar circuit to what I read in an online thesis (I wish I could take credit for this idea, but I can't). Although the author does not go into much online detail, I was wondering how to make such a switch to realize this function (I have elementary knowledge in switch realization - I don't know much beyond the basics and my couple of text books):
In the schematic, the transistor is supposed to be the output device of a class AB audio amp (I didn't draw the other half, but it would be symmetrical). Under normal conditions, the bottom of the capacitor is connected to ground, and thus the cap is charged up to ~ +50V via the supply through the diode.
When extra voltage is required, the bottom of the capacitor is disconnected from ground, and then reconnected to the anode of the diode, so that the collector of the transistor sees a higher voltage. The capacitor acts as a "second" supply in series with the first 50V supply, similar to a rail switching amp without the extra cost for more power supplies to create a "real" upper tier voltage supply.
==> But how to create the switch?!?! I think it would be a SPDT type of switch, but I'm lost as to a simple way to do it.
Old 7th March 2007, 01:38 PM   #2
elec-tron2's Avatar
Send a message via MSN to elec-tron2
Good idea !
I think that two power Mosfet can achieve this. A typical (mechanical switch like a relay) can not be used as it is far too slow.
This schematic can work. Switch M1 by applying correct gate voltage to put C1 to gnd. Then, if you want to have C in parallel with D, release M1 and switch M2. But never switch M1 and M2 at the same time.
Need to try some simulations to see how it work.
I think that power dissipated and Rds is the major problem for reliability.
Audiophile and audio products designer
Old 7th March 2007, 02:20 PM   #3
Elvee is offline Elvee  Belgium
Hi
It looks very much like the car booster amps from Philips (now NXP):
http://www.nxp.com/acrobat_download/.../AN10327_1.pdf In principle, any transistor, Bjt, MOS or Igbt could do the job.
LV
Old 7th March 2007, 02:31 PM   #4
elec-tron2's Avatar
It's look like in some way a DC-DC converter.
A good place to start
http://en.wikipedia.org/wiki/Boost_converter
Old 7th March 2007, 03:14 PM   #5
==> "It's look like in some way a DC-DC converter."
Yes, very much so... I just thought that it might be easier to implement than a true DC-DC converter because no inductors are used, just a "simple" capacitor that acts as a second voltage source in series with the first source at the right time.
The idea is that when the output of an amp approaches the power supply rail (and thus draws a lot of power to the load), the capacitor doubles the rail. Now, a capacitor is not an ideal voltage source as it discharges, so hopefully the output of the amp would diminish before the capacitor completely discharges, or else the amp will clip.
Realization system 2.1 franck1234 Full Range 8 8th August 2007 04:17 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Timed switch on B+ in power supply, good idea? shif Tubes / Valves 11 4th March 2005 01:40 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.10029 seconds (77.75% PHP - 22.25% MySQL) with 11 queries
