| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Are X7R ceramic capacitors suitable as power supply bypass capacitors in audio ckts like op amp filters, or do I need to spend the much larger amount on NP0 types?
#2 |
Here's a couple of links, read up and see if you think the X7Rs will do in your application.
http://en.wikipedia.org/wiki/NP0 http://en.wikipedia.org/wiki/X7R |
#3 |
NP0/C0G type is the better capacitor. They are more expensive and usually larger for the same value than X7R type.
TDK CAP CER 0.10UF 50V X7R 10% 0805 = $0.112 TDK CAP CER 0.10UF 50V C0G 5% 1210 = $3.30
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
diyAudio Moderator Emeritus
X7R ceramics are fine for bypassing. NP0 would be preferred in active filter circuitry. X7R ceramics have a dielectric with a higher relative dielectric constant which equates to more capacitance per unit volume.
Brian |
#5 |
X7Rs have their place in digital circuits where NPOs can't fit.
| 200V ceramic caps | AndrewT | Parts | 2 | 22nd April 2005 02:11 PM |
| Replacing ceramic caps by MKP?? | Duck-Twacy | Solid State | 6 | 21st July 2003 11:22 PM |
| ESP P68, 500v ceramic caps? | Kram | Parts | 1 | 10th June 2003 09:00 PM |
| Replacing ceramic caps - do or don't? | Cradle22 | Solid State | 4 | 16th March 2003 12:39 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| Page generated in 0.08451 seconds (59.63% PHP - 40.37% MySQL) with 10 queries |
