| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I bought a pair of Cardas GRFA (http://www.partsconnexion.com/catalog/connectors.html) for a project.
The signal wire is easy to solder. BUT I'm having a hard time soldering the ground wire. If you look at the PCX website, it contains a photo of the connector. I'm trying to solder it to the "groove". I tried 63/37 solder and silver-content solder. any tips? thank you. |
#2 |
Unless the ground connection is not made to be soldered upon (nikkel or...), you probably need more heat.
/Hugo |
#3 | |
I have a temp-controlled station. I have set it to around 450 degrees Celcius and still no luck.
#4 |
Of course the connector needs to be hot enough. Your iron seems capable.
I have nothing against Cardas, -I only know the name- but if soldering is such a though job... Maybe someone familiar with these connectors could comment? /Hugo |
#5 |
Try dismounting the RCA jack if mounted already so that there is less heatsinking. The ground portion is indeed bulky but can be heated if isolated. You'll have to finagle with wires and mounting gear perhaps already being in place before soldering. Just evaluate your setup accordingly. I used a set of helping hands to do mine and a 800 degree F tip.
| FS: Cardas female RCA (GRFA S Thick) | Monkey King | Swap Meet | 5 | 27th January 2009 11:13 AM |
| Fs:neutrik Gold Plated Rca Socket Female Chassis - Free Shipping! | YFW | Swap Meet | 0 | 24th August 2008 06:29 AM |
| Soldering Cardas Female RCA's? | dantwomey | Everything Else | 2 | 16th December 2007 04:31 AM |
| Soldering to Cardas female RCA connector | 41 | Parts | 4 | 25th July 2005 04:46 AM |
| Adding ground wire between batt and chassis | eRiCdWoNg | Car Audio | 5 | 14th May 2004 03:20 PM |
| Page generated in 0.08728 seconds (70.56% PHP - 29.44% MySQL) with 10 queries |
