Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
pc oscilloscope
pc oscilloscope
Old 20th December 2009, 04:45 PM   #21
a.wayne is offline a.wayne  United States
Sin Bin
Hello Guys ,
Looking for a PC based scope , seeing the info here is 2 yrs old maybe time for an update , any recommendations ?
Old 14th May 2010, 11:52 AM   #22
johngalt47 is offline johngalt47  United States
pc oscilloscope
No recommendations but I'm interested in protecting my sound card from high voltage when using the scope probe.
Any technology sufficiently advanced is indistinguishable from magic
Old 14th May 2010, 02:16 PM   #23
FastEddy is offline FastEddy  United States
FastEddy's Avatar
'Scope probe protection. Seek dual, series, reversed polarity parallel, pairs of Sckottki Diodes.
... across the (probe) input work very well for this = low capacitance, low impedance, fast response to any signal above ~ 3 v. AC or DC. (Reference: see input circuit diagram of some common CMOS switches ... originally used to eliminate possible input static discharge into a chip or chip set. Common on early computer motherboard and bus backplane I/O connections.)
Old 14th May 2010, 02:21 PM   #24
bikinpunk is offline bikinpunk  United States
Expensive, but from what I'm told by a friend, it's good:
USB Instruments “Stingray” Oscilloscope Review
TrueRTA also has an oscope feature built in that's nice. You'll have to make sure you build a voltage divider so you don't blow the inputs of your soundcard. That's the cheaper option.
Old 15th November 2010, 07:29 AM   #25
ganzziani is offline ganzziani
I have put together an oscilloscope comparison table where you can filter and sort devices to find the one best for your needs: Digital oscilloscopes for hobbyists | Resources
Old 20th May 2011, 03:30 AM   #26
milen007 is offline milen007  Indonesia
hi FastEddy
is this the schematic of what do you mean?
Interface Circuit for PC Soundcard Oscilloscope
any type of diode will do?
thanks
erwin
Old 20th May 2011, 03:32 PM   #27
FastEddy's Avatar
Originally Posted by milen007 View Post
... is this the schematic of what do you mean?
Interface Circuit for PC Soundcard Oscilloscope ...
YES! and it is a better graphic than mine as well.
The double diodes "clip off" every part of the signal that exceeds +/- 1.2 volts, AC or DC.
Old 20th May 2011, 09:51 PM   #28
wakibaki is offline wakibaki  United Kingdom
Banned
I've used a Picoscope 2104 which is 10MHz and costs £125. I thought it was pretty good because of the portability. The probe is part of the unit, it just went in the carry bag with the laptop and my other tools. Good for diagnosing low speed digital comms, slow micros like PICs.
The disadvantages... it's only single trace, it's good for only 20V, I destroyed mine in a moment of inattention and Picoscope were unable to repair it, I had to replace it. The fact that I replaced it says something though.
w
Old 20th May 2011, 10:18 PM   #29
CopperTop is offline CopperTop  United Kingdom
What sort of probe were you using? A x10 would have inserted a 9M input impedance in series with the input, which would be a good thing, no doubt.
But even at x1 I would have imagined that it would be possible to design an input stage protected to several hundred volts, especially on a slow-ish scope. It seems like a basic flaw in a piece of test equipment that's bound to get prodded around in mains powered equipment.
Old 21st May 2011, 12:21 AM   #30
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I like stand alone oscilloscopes.
I wouldnt risk connecting anything to my pc.
I sometimes look at high voltages on my scope but the thought of high voltages getting into my pc horrify me.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
pc oscilloscopeHide this!Advertise here!
Need help with oscilloscope error0 Equipment & Tools 2 6th April 2008 01:22 AM
Oscilloscope XTAL Parts 0 18th March 2005 05:05 AM
PC or USB Oscilloscope owel Parts 9 31st March 2004 08:55 PM
How to use an oscilloscope SimontY Equipment & Tools 15 16th September 2003 10:46 AM
oscilloscope Kilowatt Digital Source 12 22nd January 2002 12:30 AM
