| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was experimenting the LED-LDR for an indigenous attenuator. At one point, I connected one of the psu lead to the blue LED, with the power switch off. The other lead of the LED was in my hand. I saw the blueish reflection on the clear LED dome. I thought it was some ambient light reflection. On investigating, I found that the LED was lighting, very dim, off course.
Next I thought, I am connected to ground through the feet and is the reason for the LED's glow. I lifted my feet from the floor while sitting on a wooden chair with plastic bases on the leg ends, and the LED still glows, a little dimmer. Then I went measuring with DMM(Fluke77) The voltage across the LED is about 7 Vdc with line cord in one direction and about 17Vdc with the cord the other way round. The PSU is linear with 317. The RED LED also glows. Can all this be used constructively... Gajanan |
#2 |
You can easily (and safely) test LEDs with just a 9V PP3 battery to (a) check they work, (b) sort out which lead is which.
Grip one lead, touch the other to a battery terminal, touch the other battery terminal with a finger. Swap terminals if nothing happens. You may need to lick your fingers first. LEDs will glow on a few micro-amps. |
#3 |
The LED was even going dim-full. This indicated that the mains voltage was fluctuating.
Gajanan Phadte |
#4 | |
#5 | |
cpemma wrote
Gajanan Phadte |
| Dimming lights | skooter | Car Audio | 12 | 2nd December 2007 06:10 AM |
| I'm surprised this works | jallenbass | Full Range | 11 | 18th September 2007 08:53 PM |
| neon lights | Jordo | Car Audio | 1 | 21st November 2005 05:24 AM |
| very bright lights | Aetzel | Introductions | 2 | 29th April 2002 01:09 PM |
| Page generated in 0.11109 seconds (63.82% PHP - 36.18% MySQL) with 10 queries |
