| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need help. I'm looking for caps - there are too many places to find them for this newbie, and I'm overwhelmed. Can someone tell me where in US to find these caps, cheaply, and quickly?
I am replacing one 3300uf 25 Elna, and two 100uf 400v Elna - on my AN DAC Zero. I could use the same Elna's, but would I benefit to use OS-CON's, or others? This is on the PS for the DAC. I know this is a loaded question with tons of opinions involved. I would like a simple answer and some guidance please, I'm a newbie, and I need some help to replace these silly, bulging caps Thanks jake |
#2 |
Just my 2 cents...but since those are probably not in the signal path...just get some good quality replacements...www.mouser.com has no order limit...ship fast...just make sure the voltage rating meets or exceeds the caps being replaced...if you have multiple parts damaged it may indicate a wider problem in your power supply...also make sure the physical size (and pin spacing) will also fit...
none |
| bypass caps for bypassing mylar caps? | crippledchicken | Multi-Way | 4 | 27th February 2008 04:24 AM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| Silver Mica caps VS Polystyrene caps | KevinLee | Parts | 24 | 17th September 2003 03:01 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
| Page generated in 0.06555 seconds (75.36% PHP - 24.64% MySQL) with 10 queries |
