| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Any favorite pc board mount right angle rca connectors in the $1-2 range?
Scott |
#2 |
PCB mount RCA connectors all suffer from the fatal flaw of breaking loose from the board due to the mechanical stress of plugging and unplugging the connectors. The so-called "high-end" phono plugs frequently grip the connector so tightly that you can break the jack loose upon the first insertion.
Even if you use "normal" plugs on the cables, the jack will eventually break free of the PCB. If you must use a PCB mount connector, look for one that mechanically attaches to the box as well as soldering to the PCB. Good luck! You're going to need it! I_F |
#3 |
I bought a bunch from Electronics Goldmine a year or so ago. They looked like the low end WBT (still great plugs). They are both chasis and PCB mount. I think they have sold out, but it's always good to keep an eye out at the surplus places since their inventory is constantly changing.
Listen to the music through the stereo, not the stereo through the music. |
#4 |
Vampire had some decent board mount rca's but I agree with the problems that board mounts have. They are convenient, but they just don't hold up well. Even if they build them well enough so that they themselves don't fall apart, I find that within 5 years or so the solder joints crack loose, sometimes even doing damage to the boards, such as the pads falling off. You can get much better quality chassis mount RCA's for the same or less, and won't have the problems. I get mine on Ebay, usually can find 20prs or 50prs for very cheap, I think I paid 10 dollars for the silver plated ones.
| Sure Electronics New Tripath Board 4*100W class-D Amplifier Board | 7788q | Class D | 312 | 18th May 2012 01:32 AM |
| pin to socket connector to mount small board? | riotubes | Parts | 1 | 23rd September 2007 04:48 AM |
| WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x | Destroyer OS. | Swap Meet | 1 | 22nd December 2006 06:18 AM |
| FS: Neutrik Combo Board Mount Jacks | antness | Swap Meet | 3 | 19th January 2004 04:25 AM |
| Page generated in 0.08939 seconds (62.54% PHP - 37.46% MySQL) with 10 queries |
