Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
ROE Capacitors
ROE Capacitors
Old 2nd March 2013, 02:40 AM   #21
Karl vd Berg is offline Karl vd Berg
Karl vd Berg's Avatar
Originally Posted by jacco vermeulen View Post
The main reason to parallel small electrolytic capacitors instead of one biggy.
Which one mainly does with class AB power amps, or e.g. preamps.
In class A power amps, big cans are preferable, as total uF value is the primary target (and large ones have a better/higher uF/volume ratio)
(e.g. Classé, Sphinx, AVM, Swiss Physics, Orpheus)
Hoi Jacco!
It's for the use in an Integrated amplifier Yamaha, rated 85Wrms.
I have already decided to replace the 2 main big cans of the old 12,000uF 63V with fresh new 4x 3300uF 100V Nippon Chemi-com high ripple current, having a total of 13,200uF 100V higher ripple current reservoir capacitance per rail. It will make things much easier, better and faster for the signal path.
Other than that, it's much cheaper than buy 2 cans of 15,000uF and much efficient.
Regards to all!
Old 2nd March 2013, 11:50 AM   #22
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
It gets even better.
$/(uF x Vrated) is somewhat of a constant (margin) for a brand series.
Buying 1 or 100 differs by over a third in price/pc.
A DIY who builds a couple of power amps may be cheaper off to get 100 of 2200uF caps, than 10 of the same type in a 22.000uF value.
(back in the '80s, I calculated every imaginable ratio number of just about every amp part. call me a numbers freak)
Old 3rd March 2013, 02:16 AM   #23
Something in Europe can be found here:
Roederstein :: Electrolytics :: Capacitors :: Passive Components :: Electronic Parts :: Banzai Music GmbH
And for Jacco, we now have also this supplier in Amsterdam:
EOO - ElectronicaOnderdelenOnline
ROE CapacitorsHide this!Advertise here!
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
