| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I´m amazed!
#2 |
I have an educated guess that it is a TL082 made by JRC.
TL082 is a general purpose JFET input dual OP amp. |
#3 | |
I agree. JRC always chops off the first letters or numbers in a given opamp design they copy or licence. If the vincent unit has a phono section, this is likely where the TL072 is. Or a line buffer for tape out.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#4 |
i have googled and found:
manufacturer is: jrc , org. part number: 082d maybe, more you will find by your google try.... ;-) |
#5 |
I´m amazed!
Errh ... Believe me, I´ve googled a lot, but only searched for 2039, not 082 ...
![]() Thanks! |
#6 |
Its a pity that many parts don't have the full designation branded. One would almost think they want to save some ink.
/Hugo |
#7 |
The 2039 is probably the date code. 39th week in 2000. G is probably a lot #.
#8 |
diyAudio Moderator Emeritus
Don't bother finding the datasheet and replace it for LM4562 straightaway. If you do, please use a small cap right across the + and - supplypins as with all high BW opamps.
It's only audio |
#9 |
Better Realistic EQ's have the exact same chip. I can confirm it's a TL082.
#10 |
That makes me wonder what opamp is in the less good Realistic EQ's ....
It's only audio |
| doesn't sound quite right | DannyPs19 | Tubes / Valves | 2 | 7th May 2008 12:57 AM |
| PC doesn't boot | Devil_H@ck | Everything Else | 41 | 8th June 2005 08:41 PM |
| A DIY DAC that's easy and doesn't cost TOO much. | marios_mar | Digital Source | 1 | 8th September 2003 09:24 AM |
| Amp doesn't like computer :/ | Bryanm | Solid State | 1 | 18th June 2003 10:02 PM |
| Page generated in 0.12667 seconds (62.29% PHP - 37.71% MySQL) with 10 queries |
