Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to measure amp power output
Old 14th February 2007, 06:23 PM   #1
hernanstafe is offline hernanstafe  Argentina
Default How to measure amp power output
I'd like to know if there's a way to measue an amp's power output using a regular multimeter...?
Old 15th February 2007, 04:39 PM   #2
AndrewT is online now AndrewT  Scotland
you need a sine wave signal source,
a scope to see clip free voltage,
dummy load.
When you have those come back.
regards Andrew T.
Old 16th February 2007, 01:27 AM   #3
KISS is offline KISS  United States
Most specs are for both channels driven, so you may want 2 dummy loads. For giggles, you may want two 4 ohm loads and two 8 ohm loads. The power rating of the resistor needs to be greater than the expected output.
How to measure amp power outputHide this!Advertise here!
Measure the output of a bridged class D ocool_15 Class D 5 20th April 2008 07:12 PM
How to measure the output impedance of the DAC chip ergo Solid State 2 9th June 2004 07:07 AM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
How can I measure dB output? Duo Multi-Way 30 24th April 2003 02:53 PM
How to measure digital output of CD. protos Digital Source 0 5th March 2003 11:50 AM
Copyright ©1999-2017 diyAudio
