Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
CDM9/65 puck problem
Old 14th February 2007, 11:11 AM   #1
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Default CDM9/65 puck problem
Hi everyone.
I have just been given a Rotel RCD975 with a problem.
I can only play discs if I load the player and then turn the machine upside down. It seems like the puck is rubbing or catching and the motor can't turn the disc.
Anyone any ideas? The transport is cdm 9/65.
Lee.
Old 16th February 2007, 01:33 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It may be a faulty spindle motor. If you find more evidence in that direction, try to replace the motor by a similar one, or try to *carefully* dismantle it by removing the bottom cover, then clean the brushes and the collector and then mount it again. You can also try turning the disc manually just after pressing play and see if that helps the motor to start.
I use to feel like the small child in The Emperor's New Clothes tale
CDM9/65 puck problemHide this!Advertise here!
Datasheet for CDM9 / CDM9 Pro Lgrau Parts 1 19th February 2012 08:22 PM
Difference between CDM9/50 & CDM9/60 kik73 Digital Source 1 12th April 2010 01:21 PM
Krell MD 2 Puck Ring gto127 Digital Source 0 20th August 2009 09:49 PM
Is the CDM9/63 compatible with CDM9/44 philpoole Digital Source 0 14th November 2006 03:02 PM
I feel like dropping the puck, so I will. KBK Solid State 14 18th November 2005 07:38 PM
