Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th February 2007, 12:43 AM   #11
cpemma is offline cpemma  United Kingdom
WE had this discussion in Class D re adding a small sink to the T-amp chips; opinion was Superglue (cyanoacrylates) has too low a temperature limit (though this seems to vary with brand, so YMMV).
I used (on recommendation) JBWeld, a filled epoxy claimed to stand red heat; does the job.
I'd certainly expect the thermal epoxies sold for the purpose to be better, but they're hellish expensive.
Like any other TIM, the thinner the bond, the better the heat transfer.
Old 14th February 2007, 04:18 AM   #12
radtech is offline radtech  United States
I was looking at the arctic silver site and they warn that once you glue a heat sink on with their stuff, it ain't coming off.
So my question is, what would you use if you wanted a thermal glue that wasn't quite so permanent?
Old 14th February 2007, 04:35 AM   #13
EdT is offline EdT  Canada
All epoxies will gell and pry off at 200Deg C.
Epoxies has structural strength and Superglue does not, they will shear the second there is impact or leverage, also the texture on most chips will leave small gaps which limits proper thermal transfer. The best glue based product is from Loctite, they have a two part activator type glue that is fast and effective.
Another option for low heat (up to 120Deg C) and non-permanent applications is thermal tapes. The best ones are from Chomerics, their silver impregnanted acrylique aluminium meshed double sided tapes are the best and the regular aluminium foil or silicone based transfer tapes found on most PC based application
I stuck a heatsink on the TA2024 with just the regular AL foil transfer tape, it has more than enough holding strength.
Old 14th February 2007, 09:46 AM   #14
what's all this talk of 100+ degC?
If Tc is that hot the chip is beyond starting to struggle.
If I were adding a heatsink to an overheating chip then I would be looking for Tc<70degC and preferably <50degC.
Cyanoacrylate easily survives these temperatures.
And the low viscosity also fills all the crevices and undulations.
regards Andrew T.
Old 14th February 2007, 10:32 AM   #15
AuroraB is online now AuroraB  Norway
AuroraB's Avatar
Well... I've used the Loctite "Output 384" for several years now. Made for the purpose of glueing heatsinks and the likes, bonds well if instructions are followed, and prys off *fairly* easy by using a knife edge or something...
Costly - prb'ly is- I use it professionally, so I don't pay from my own smallish heap of doe...
The PC crowd hails the Arctic silver stuff, but I have never used it....
Everyone to his own taste , I guess.......
Heat sink and chokes FS broadcast guy Swap Meet 0 22nd November 2004 08:23 PM
Yet another heat sink problem OliverD Pass Labs 10 16th October 2003 06:29 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 06:23 AM
Page generated in 0.08164 seconds (74.23% PHP - 25.77% MySQL) with 11 queries
