Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th February 2007, 04:10 AM   #1
hifiger is offline hifiger  Canada
Send a message via MSN to hifiger
Default Crossover dillemma,..
I was hoping that someone here would be able to help me with this problem. You see, i have built a horn sub similar to the Horn Sub JR, on the cowanaudio website.. The issue is that i forgot to install a high pass filter into it when the driver was still easilly accessable. I have used MDF to make the horn, and am very reluctant to unscrew anything.
I am comfortable with having only a 6db octave slope starting at 40-50hz as the modification is intended for spl while playing music. Is it possible to mount a crossover cap on the signal in side of the plate amp, or is the input impedance going to cause an issue?
What is the impedance present at say, the line in on the plate amp?
Thanks in advance
Peter-
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
What should I use for a crossover? punkrokr1701 Everything Else 1 10th September 2006 07:27 PM
Help with crossover ShinOBIWAN Multi-Way 2 19th February 2005 03:29 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.06905 seconds (68.49% PHP - 31.51% MySQL) with 10 queries
