Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th February 2007, 02:44 PM   #1
TDWesty is offline TDWesty  Canada
Default Cisco power supply?
I have a spare Cisco power supply from a Cat 6000 switch, which is rated at 1000W, 48VDC output. Is the transformer from this unit likely to yield something useful for a chipamp (briangt) project? I haven't yet pulled it apart, as it still has some value. Or is 48VDC too much to deal with? I assume it is regulated, so the transformer output will be higher than this.
I'll try to check the secondaries and see what they actually put out.
On a similar vein, are UPS transformers any good for anything? All the small ones under 1000VA seem to be 12V only.
Shawn
NAD 3125 & 3020 amps, 4125 tuner / Rotel RCD-965BX CD / B&O 2400 / Nakamichi BX-125 / PSB 70R speakers / BrianGT chipamp in progress...
Old 6th February 2007, 02:49 PM   #2
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default cat6000
These are switching power supplies...no transformer to pull out..and for what a 6000 power supply costs...you could just sell it and buy an amplifier...
none
Old 6th February 2007, 03:16 PM   #3
Default Re: cat6000
Thanks. So is it safe to assume that all of this stuff uses switching PS these days? From the size of the Cisco, I thought maybe it wasn't. It's only the 1000W unit, so it doesn't have much value these days... we upgraded to 1800W supplies.
Are the UPS units also switch based? An APC 500VA UPS has a decent sized transformer, but I assume only 12-15V.
Shawn
Old 6th February 2007, 04:49 PM   #4
Default UPS
Most UPS have a transformer...but its probably 12 volt out to charge the batteries...so uses are rather limited...however any UPS or power supply may have capacitors, heat sinks, bridge rectifiers and other items of interest..
none
Old 17th February 2007, 09:00 PM   #5
we are outpulling some defect (site wireing fault) APCs UPSs 700 and 1000VA. If anyone need things are useable off this def. pieces...
but the are very heavy; cost alot of shipping...
please mail soon if interestetd, otherwise they will be dumped...
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.10008 seconds (68.03% PHP - 31.97% MySQL) with 10 queries
