| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Ok i've just built an amp using TDA2030 IC, i used the single power supply version of the circuit tanken off the component Datasheet. Now, i've tested it with a computer power supply and it works ok, but i'd like to build a power supply for it but if i use a common one, i get a horrible sound, so i take it it has to be very very filtered if not regulated (if i'm not wrong, it has to have very small ripple...)any schematics for such thing? cause i thought using LM7812 to regulate and capacitors to filter but i'm not sure if it'll be enough.
Thanks again everyone! |
#2 |
most decent chipamps have adequate Power Supply Rejection Ratio (PSRR) to hide the small ripple at quiescent conditions and to hide the big ripple when delivering significant output current. A conventional unregulated PSU consisting of just a transformer + rectifier + smoothing cap is usually enough for a single supply ?Vdc to 0Vdc. Be careful to ensure the maximum voltage from your PSU is less than the absolute maximum Chipamp voltage requirement.
regards Andrew T. |
#3 |
The 78xx series regulators are easy, stable and reliable. They however, are not so good at rapidly changing current draw. You want to use a series pass regulator. You may also try a much larger filter cap on the one you have.
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Can i use a computer power supply to power audio amplifiers? | destroyer X | Solid State | 91 | 25th September 2006 04:36 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.09768 seconds (71.50% PHP - 28.50% MySQL) with 10 queries |
