what kind of resistor is this? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd February 2007, 10:06 PM   #1
pchw is online now pchw  United States
Default what kind of resistor is this?
I got some of these 10K 1% resistors, but I never saw anything like that. It has a hole in the middle. I wonder what is the power rating and type (carbon, metal, ceramic etc)? Can someone identify it?
Thanks,
- Fred -
Old 2nd February 2007, 10:11 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Re: what kind of resistor is this?
Thanks,
I would cannibalize one to see what is inside, you are happy if a metal foil or wire.
The Devil is not so terrible as his math model is!
Old 2nd February 2007, 10:15 PM   #3
frank754's Avatar
I just ordered a few that look similar, mine are Caddock high-power, low tolerance "film resistors", they generally are in the low resistance range, but can go up to 100k or so, and are a premium price, like $3-4 each sometimes.
They sort of look like flat transistors but a bit larger, and are fairly high precision, some have flat PCB type leads (or socket leads).
Old 2nd February 2007, 10:31 PM   #4
Yeah, they do have a look of transistor.
The markings are 10K ohm (the symbol) 1% CE292E. The packaging is kind of like thick plastic or epoxy shell. The diameter is about 20% bigger than a pencil. I google searched CE292E but turned up nothing. Do you think it is safe to use them as 1/2W resistors?
- Fred -
Old 2nd February 2007, 10:35 PM   #5
nhuwar is offline nhuwar  United States
nhuwar's Avatar
If I were to bet I would say it's a copper coil resistor by it's shape.
Nick
Old 2nd February 2007, 11:01 PM   #6
frank754's Avatar
Yes, that's another thing I neglected to mention, the reason some of these are so large is that they can handle often 15 watts, and some are rated up to 100 watts. I can't tell what yours are from what you say, but the ones I ordered say "MP925 100K 1% R" and are rated at 25 watts, the dimensions are .4" x .6" x 1/10" thick, and cost me about $3.50 each, so big performance in a small package.
Old 2nd February 2007, 11:10 PM   #7
Come on guys!
It is a wirewound ( probably manganine) precision resistor.
Designed for stability, not high power or any other audio freakiness!
I have LOTS of similar.
Old 2nd February 2007, 11:17 PM   #8
jlsem is offline jlsem  United States
jlsem's Avatar
Probably a 1/4 to 1/3 watt and no more than 300v. Looks like RB53 size.
John
"Those who abjure violence can do so only because others are committing violence on their behalf." - George Orwell
Old 2nd February 2007, 11:21 PM   #9
frank754's Avatar
The ones I got were from Allied, as I had a hard time finding a certain spec I needed, and these are 25 watts. precison, are are that small:
I was just guessing on his.
Old 2nd February 2007, 11:38 PM   #10
I wish they were the same type, Frank
Here is another picture, Cliff, do they look like manganine?
If they are only 1/3W at most, then they are probably not much of any use, what a bummer.
- Fred -
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
What kind of RESISTOR is this??? slownlo Parts 11 1st January 2004 04:10 PM
Which kind of resistor? randytsuch Chip Amps 35 9th July 2003 02:05 AM
What kind of cap is this ? (2) rbroer Parts 5 11th February 2003 03:39 PM
Copyright 1999-2017 diyAudio
