| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hy,
There are programs that draws frequency range of capacitor but value of capacitor is fixed and calculated by program, that is program for making crossfires and boxes for loudspeakers. Is there a program that draws frequency range of capacitor, but i must set value of capacitor? |
#2 |
The frequency that a Capacitor filters depends on the Impedance if the signal, So for a Crossover for instance a capacitor will filter different frequencies depending on the Impedance of the speaker...
Also for Crossovers Inductors are alo used in conjunction with the Capacitor and the resistance of the Speaker to form a Filter..... This calculator should tell you what Cap to use and what Inductor to use to filter what frequecny for what speaker.... http://www.the12volt.com/caraudio/crosscalc.asp This calculator does the same thing but seems Like it is Not just for crossovers but for EQ"s and other Filters.... http://www.opamplabs.com/cfl.htm Google is your Friend.... Cheers |
#3 |
are you looking for a way to measure a reactance/frequency curve to find component resonances???? not really sure what you're asking.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| how much power for which frequency range? | Dominique | Multi-Way | 12 | 24th November 2006 05:35 PM |
| SNR/Dynamic range worsens in low frequency range. | percy | Digital Source | 3 | 1st June 2006 12:41 PM |
| Frequency CUT and a HOLE in frequency range... | -_nando-_ | Everything Else | 0 | 28th December 2005 08:17 PM |
| Page generated in 0.09639 seconds (54.97% PHP - 45.03% MySQL) with 10 queries |
