Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2007, 08:15 PM   #1
megajocke's Avatar
Default What is this connector called?
I wonder what the PSU connector on the older Soundcraft mixing desks are called. Here is an eBay auction for a power supply:
http://cgi.ebay.com/Soundcraft-CPS-1...QQcmdZViewItem
The connector has two rows of pins, one with 3 the other with 2 pins. There is also a locking ring. I'm going to build a new power supply, a replacement from soundrcaft costs 600$ or something and it's not even complicated... (LM338 regulators )
Old 30th January 2007, 05:08 AM   #2
unclejed613's Avatar
can't be absolutely sure without my huge Newark catalog, but my first thought is either Switchcraft or Amphenol
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 30th January 2007, 05:15 AM   #3
Looks like a locking 5 pin XLR plug to me
Old 31st January 2007, 09:06 AM   #4
AndrewT is online now AndrewT  Scotland
it looks like a 180 degree 4pin with an extra 5th pin in the centre.
That is different from a 180 degree 5pin.
It's the 5th centre pin that makes it unusual.
Difficult to tell the size of the connector but is may be XLR or if smaller could it be DIN?
But, again I have not seen a 180 4pin with 5th centre in DIN sockets.
Cut it off and fit a 5way XLR at both ends.
regards Andrew T.
Old 31st January 2007, 03:02 PM   #5
Apex Jr is offline Apex Jr  United States
It kind of looks like the military MS 3116F series connector
but I think it's a Japanese JRC connector same series
used in the older Video cables.
Steve @ Apex Jr.
Old 31st January 2007, 03:30 PM   #6
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Amphenol 6-pin with PE
only 4 pins + PE used
http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 7th February 2007, 04:50 PM   #7
megajocke's Avatar
The connector is Hirose I think, there is a HRS logo in the plug on the mixer.
http://www.hirose-connectors.com/con...=ALL&Shell=ALL
But which one is it?
edit: Think I found it: 5 pin JR series (JIS C 5432 standard connector)
But where do I get it? Maybe 5 pin xlrs are the best solution, but then you won't be able to use the original power supply
Old 7th February 2007, 05:24 PM   #8
megajocke's Avatar
Found it... JR13PK-5S
RS has it, but I don't have a business so I can't buy from them
Old 7th February 2007, 05:47 PM   #9
FastEddy's Avatar
" ... The connector has two rows of pins, one with 3 the other with 2 pins. There is also a locking ring. ..."
" ... I'm going to build a new power supply, a replacement from soundrcaft costs 600$ or something and it's not even complicated... (LM338 regulators ) ..."
Good show. As long as you are building a new PS, you should replace this very "non-standard" connector with something better and more easily obtainable. (If you absolutely have to keep this connector, just find a 5-pin "DIN" type that fits the pins (and holes on the reciptical) and not necessarily the locking ring, etc.)
Old 7th February 2007, 06:08 PM   #10
That took some searching.
but back to previous advice
regards Andrew T.
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
what is this called skullkeeper Parts 1 23rd April 2009 11:28 PM
What is this cap called? intensem1rider Parts 6 20th March 2008 05:34 AM
What's it called? Cal Weldon Multi-Way 10 16th June 2007 05:29 PM
Page generated in 0.10616 seconds (78.29% PHP - 21.71% MySQL) with 10 queries
