Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2007, 11:30 AM   #1
Stuey is offline Stuey  Australia
Default Cross referencing Toshiba transistors
Hi guys,
I'm new to refurbishing older amps, and need some transistors to replace 2 Toshiba complimentary pairs of 2SA1263 and 2SC3180.
Has anyone any suggestions of currently available transistors that will suffice? I'm not sure if the cross referencing on various websites is reliable enough.
Which parameters must be matched in the replacements?
Cheers and thanks
Stuey
Old 29th January 2007, 01:10 PM   #2
Pin pitch, Power, Ic, Vce0, SOA @ rail voltage, hFE, Ft, Cob, or exceeded if a close match is not possible.
regards Andrew T.
Old 29th January 2007, 01:38 PM   #3
Did it Himself
richie00boy's Avatar
Although a lower Cob would be preferable
If the devices are TO247/TO3P case then Toshiba's 2SA1943/2SC5200 will be fine, as will Motorola's MJL3218/MJL1302 or MJL21193/MJL21194.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 29th January 2007, 02:10 PM   #4
Pars is offline Pars  United States
Pars's Avatar
Both bdent and MCM have these in stock. I would recommend BDEnt if you need a specific gain range (not sure if these particular transistors have different gain classes or not... MCM is clueless when it comes to that however).
Old 30th January 2007, 09:49 AM   #5
Thanks for the replies.
The package is SOT-93, so I'm assuming the TO-247 legs can be manipulated to fit... Not only that, but my usual electronics store has them.
I have heard of one repairer using TIP2955/TIP3055 (which is in the same case - SOT-93) but I'm assuming the Motorolas are more suitable? They are certainly more expensive! Still, I'd prefer quality. This is a gift repair for someone.
Pars, I'll have a look at those links. I didn't think the originals were still available.
Cheers again.
Stuey
Old 30th January 2007, 10:18 AM   #6
Did it Himself
SOT-93 is basically TO-3P is basically TO-247.
3055/2955 devices are a cheap and poor replacement not upto the spec of the original devices.
Old 30th January 2007, 10:28 AM   #7
Thanks Richie...I appreciate your input.
As for the format, I've found that it's correctly a TO-3P case anyway; I was wrong.
I'll try the links Pars gave, otherwise I'll buy the local Motorolas. I meant above that my local store has the MJL21193/21194. At least at AU $9 and $11 each respectively, they are probably genuine...!
Cheers
Stuey
Old 30th January 2007, 05:18 PM   #8
the 21193 is nowhere close to the Tosh 1263.
I thought you asked for an equivalent.
regards Andrew T.
Old 30th January 2007, 10:13 PM   #9
I asked for a replacement that will suffice. I'm assuming that Richie listed those because they exceed my requirements...?
In any case, the links Pars provided both list the originals. I'll try them first.
Thanks everyone
Stu
Old 30th January 2007, 10:31 PM   #10
Did it Himself
I listed the alternative devices in order of preference. The MJL2119x devices whilst not stellar performers are very robust and will be fine as replacements. Certainly a lot better than 3055/2955 ones.
cross-referencing transistors jarthel Parts 1 19th July 2007 03:11 PM
For sale Toshiba Transistors Xtreme Swap Meet 0 14th March 2007 12:10 AM
WTB toshiba transistors max29 Swap Meet 0 6th December 2006 08:53 AM
Authentic Toshiba Transistors audio89 Parts 0 9th November 2005 05:03 PM
Where to buy Sanken and Toshiba transistors weinstro Solid State 5 8th October 2003 10:58 PM
Page generated in 0.10128 seconds (76.34% PHP - 23.66% MySQL) with 10 queries
