| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Extremely handy link on fluoro based insulation
I've just saved a load of .pdf's on things like the electrohydrodynamics of dielectrics too. I'll look through them later and let you know if I find anything interesting. |
#12 |
Seems these guys offer a porous teflon with a structure similar to cellulose paper - so the dielectric would flow nicely.
teflon tape If I had to choose a fluid for this I think I'd use 3M Fluorinert FC-87 since it has a really low viscosity (about half that of water). Boiling point is also the lowest of the series, but so is it's minimum pouring point. So I'd stick it (dried) & the dry cap in the freezer and then vaccuum infuse. One thing to offset the fluid's pocket filling behaviour is that the solid layer it's self looses some degree of homogeneity and dimensional stability when using porous tape - e.g. the more flexible the dielectric becomes (making it's structure porous like cellulose paper) the more the electrostatic forces between the plates can compress it. It might be worth trying the same thing with a solid tape and blasting it with Fluorinert under vaccuum. That way you fill air pockets (and even if it's tightly rolled, I'm guessing there'll be a suprising amount of bubbling under vaccuum), you keep the structural strength of the solid tape and you use less fluid per cap (important given the cost). Talking about macro properties of course, so it just depends which has the slightly larger effect. If the fluid produces a significantly improved discharge characteristic (due to it moving like you suggest), then the porous tape would still be the best idea - despite providing less plate support. Maybe ask the tape manufacturers if they produce the tape in different rigidities. |
#13 |
Nice source for porous ptfe, John. I get mine from DeWal. I will be using FC-72, which is the lowest dielectric constant version. I used FC-84 in my early prototype. Interestingly, the porous ptfe absorbs the Fluorinert like water in a paper towel. Electrochemicosomething attraction methinks.
Don't equal capacitor electrostatic forces exist on both sides of a plate, and thus cancel? |
#14 |
By the way, Fluorinert doesn't vacuum infuse. Tried that.
#15 |
FC-72 (or PF-5060, as the barrel says) is the one I have. Pretty pricey stuff! Let me know if any of you want to buy some, I have a couple of gallons.
#16 |
sounds like a good idea for a product. Do you have any plans to offer them for sale?
The freaks stick together, they are a tight old crew |
#17 |
Yes, I'll happily sell to interested DIYers at cost. I'm expecting the first prototypes in a few weeks, depending on the manufacturer's time frame.
#18 |
Tom, can you give us info on what values and rated voltage will be available? Thanks
#19 |
Values and voltage ratings are unknown at present as the project is in the experimental phase. I'm currently using two Fluorinert in paper caps at 75VDC, which is the maximum I've put across them. With 0.001" teflon + Fluorinert, I'd think max V would be several hundred volts. Actual measurements will tell.
As to values, much depends on how physically large the units are. Values probably will be in the range of 0.1uF to 0.47uF. |
#20 | |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Box capacitors | speakerguy79 | Parts | 2 | 14th March 2007 02:55 PM |
| Continental Capacitors' "Type-A" oil-filled capacitors? | radical | Parts | 0 | 21st October 2004 08:39 PM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
