j50+k135 mosfet replacments - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th January 2003, 07:15 PM   #1
Default j50+k135 mosfet replacments
can anybody sugest either a suitable replacment or a source for these transistors as my sub is rather queit without them
all i could find on google were japenese sites that i have a bit of trouble understanding,and none of my catoulges or data books list them.
hippy
Old 5th January 2003, 07:43 PM   #2
Hi hippy
They can be replaced with [ 2SK1530 in the place of 2SK135 ] and [ 2SJ201 in the place of 2SJ50 ]. The new transistors are in plastic case ÔĎ-3Ń and no TO-3, bear in bigger supply of operation and have positive factor of temperature. This mean that with the increase of temperature, is increased and the current that is gone through from through the transistor.
Old 5th January 2003, 08:01 PM   #3
many thanks sir,i went over top on the heatsink so the increase in tempreture shouldn't be a proplem,if it is then i'll add more metal
cheers hippy
Old 5th January 2003, 08:12 PM   #4
Old 6th January 2003, 08:36 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
I have couple 2SK135 and 2SJ50 for sale.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 6th January 2003, 09:54 AM   #6
vuki is offline vuki  Croatia
vuki's Avatar
Default fet source
Hi hippy,
I think this will help you: http://www.borbelyaudio.com
Old 6th January 2003, 10:17 AM   #7
Default mosfet replacements
Try 2SK1058 and 2SJ162 which are the plastic equivalents/replacement from Hitachi. You can compare their specs by doing a search at google.com
ckt
Old 6th January 2003, 11:18 AM   #8
In my amp the K135 and J50 broke down: the MOS gates were leaky, apparently the protection diodes did not work so well after all.
I used the BUZ901 and BUZ906 parts. However expensive, they are far more robust. I never had any problems ever since, but maybe the price is a bit of an overkill for a sub amp.
Anyway, success, grtz bart
Old 6th January 2003, 02:11 PM   #9
peranders's Avatar
The protection diodes are zeners and must be protected against over currents. The zener voltage is +-14 volts.
You can break these diodes if you have no control over the output current and/or the driver can deliver too much current.
An easy way of current limitation is to attach zeners with voltage under 12 volts.
My experience of K135/J50 (when designed in correctly) is very good. Noone has been to any trouble. I think Nelson Pass can say the same thing.
Old 6th January 2003, 09:13 PM   #10
thanks for all the help,will compare prices\specs of the varies devices sugested,and most importantly which ones my local supplier stocks
BiCMOS Bipolar+MOSFET better than MOSFET lineup Solid State 5 8th December 2009 12:46 PM
J49/K135 Fets.............Anybody have these? slizm Swap Meet 20 8th March 2009 10:07 PM
Need K135 Have new J50's for trade or $$ Zero Cool Swap Meet 6 8th February 2008 09:33 PM
resevoir cap. replacments, recommended makes lt cdr data Parts 2 23rd December 2005 07:36 PM
Extra K135 Mosfets soon available Zero Cool Solid State 4 17th October 2004 07:27 PM
Copyright ©1999-2017 diyAudio
