Building An Equalizer
Hi everyone,
I've got plans to build my own EQ, and I've been looking around at pre-drawn schematics, but being no electrical engineer, I've got a whole myriad of small questions. First, I should explain what I'm hoping to achieve: > 10 bands per ch. for 2 channels. > Master gain/attenuation for both channels at once. > Knob-style pots to conserve space. > A final design fitting within a 1U 19" rack enclosure. > As little added noise as possible. Here is one of the schematics I've been looking at. To the best of my knowledge, those op-amps will do just fine, but that opinion is biased towards the fact that I wouldn't know what to do with the circuit to use different ones. :smash: For the questions though, these are mostly small, but I would really appreciate any help determining the following: > How to double up to cover both channels separately. > What considerations I should take regarding the power supply. > If anyone happens to have a spare enclosure (any kind) they could sell me... > And finally, if any of that design would remain in tact should I wish to use different op-amps. Of course, I can give more details upon request, but that's the basics of it I think. Thanks! - Brian Ziemek [Edit: Posted the wrong schematic.] |
Here's a page with some other EQ designs, parametric and graphic using gyrators, you might want to have a look at those.
http://www.ethanwiner.com/spectrum.html As for opamp type, you'll probably not want to use 741's. There would be little if any change in the circuit when using other opamps. 5534's would probably be a good choice. To make 2 channels you'd simply duplicate the equalizer part, and use one power supply to power both. |
Many thanks for the replies everyone.
- Brian Ziemek |
| All times are GMT. The time now is 06:06 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
