Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th January 2007, 01:59 AM   #1
Default Power trans coupling with speaker, causing hum
I have a Fender Pro Jr tube amp that I've ugpraded/modified extensively. Hiss is way reduced, and there's no hum or buzz in the signal unless it's turned up all the way.
However, it seems the power transformer is coupling directly with the speaker, which is only about 6 inches away. In the 5-10 seconds before the tubes warm up and hiss fades in, I hear a quiet hum. Actually, it's there even if I unplug the speaker from the chassis.
I already relocated the output transformer and put a shield between it and the PT (small angled piece of sheet metal, thanks to Bill Machrone for that one), and that seems to have eliminated almost all output trans. related hum.
But how to shield the speaker from the power transformer? I'm sure the stock Pro Jr PT is just cheap, and getting a good replacement with a built-in shield would solve a lot of it. But is there any simpler solution, short of trying to construct some kind of massive homemade shield?
The hum is quiet and it's not a huge deal, but having come this far, I'd like to get rid of that last bit if at all possible...
Linear power supply causing mains hum at speaker cmhadley Power Supplies 5 18th April 2009 02:43 PM
Power Trans, 45V-0-45V pistoljoe Swap Meet 1 15th April 2008 10:39 AM
Power Trans Question cominup Parts 8 9th June 2005 08:06 PM
Power Trans. Sockets or not mashaffer Solid State 5 15th May 2005 03:18 PM
cap on speaker causing amp to cut out dvdwmth Chip Amps 1 12th September 2004 10:00 PM
Page generated in 0.06272 seconds (69.11% PHP - 30.89% MySQL) with 10 queries
