| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I found these caps in my Luxman R-115 I just powered up after probably a decade of rest in someones basement. The orientation is correct, this brown stuff is on the topside of the cap, I'd expect it to run down, so I'm not sure if it came from the cap. No other brown like this anywhere in the unit. I'm not sure if it is leaking from the cap, could it possibly be some kind of glue? It is not liquidity, it is dry. The caps read .08 on my ESR and they are daisy chained, so the value is good. They are 1000uF/35volt. The unit does act a little funny, I think the filter caps may be bad, but that is a subject of another post. Should I change these, though they read fine?
#2 |
Looks like glue to me, but you might want a second opinion.
#3 |
Looks like glue to me too.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
"Is this under a perforated portion of the cover?"
Yep. The entire topside has perforations on this unit, these caps are directly below. And there was a huge glob of wax on the mainboard towards the back and on some of the rear connectors. The previous owner was using the receiver as a candle holder, apparently... |
#6 |
They sure made em big in the good ol' days hey... at least if the bug bites, those will be cheap swapouts, and you could easily even get higher capacitance caps in there in the same size....
#7 |
I have some NOS 50v 2200uf Nichicon VX caps you can have for the low low price of FREE! They are approximately 18mm x 35mm. If you think you can make them fit just drop me a mail with your addy.
Pic of caps |
#8 | |
#9 | |
| Bass driver behaviour in "leaky box" | FE3T | Car Audio | 1 | 28th July 2009 08:23 PM |
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| What constitutes a leaky Coupling capacitor? | Drewaudio | Tubes / Valves | 5 | 23rd September 2007 06:33 AM |
| Leaky 9900 Revelator? | mazdapowered | Multi-Way | 6 | 22nd November 2006 05:29 AM |
| what is a 'leaky' transistor? | loonatron | Analogue Source | 8 | 17th March 2005 10:55 AM |
| Page generated in 0.09101 seconds (82.54% PHP - 17.46% MySQL) with 11 queries |
