Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th January 2007, 07:50 PM   #11
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Hi thank you for the recomendation, but again, I think you missed the point I was making. First, I never had any intention of buying a high end power cable. I always intended to make my own. My point was simply that, regardless of the rating of the products used to create the power cable, according to an insurance investigator, its still not acceptable by there standerds, and he claims is not a UL rated product as he understands the way that system works. He knows insurance won't accept it, and isn't sure if the goverment would. I also know that in my family business its not acceptable for medical use unless built by a licensed electrician, which he also said was how insurance companies did things.
Old 14th January 2007, 08:24 PM   #12
diyAudio Moderator Emeritus
roddyama's Avatar
The problem in spending much time, effort, and money on equipment power cables is that you turn around and plug it into the wall socket. If one doesn't consider the wiring coming from the breaker box and into the house and..., than it's just an exercise to contemplate and waste time on.
If you already have a cable/wire that will carry as much or more current as your breaker will allow and it has an insulation that will handle the voltage, it's probably safe to use and will work as well as any. If the house burns down, well,... the insurance company is a different issue. UL is the only way to go.
Rodd Yamashita
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
Amp4 Mod Round-up – Input wire, power caps and high capacitance speaker cable Peteruk Class D 10 4th April 2007 06:12 PM
25 pair cat 5 cable for speaker cable? mpmarino Parts 19 3rd March 2006 04:46 PM
electrical cable for DIY speaker cable? leadbelly Multi-Way 7 13th January 2004 10:43 AM
Internal speaker cable for high power disco/pa cabs Bull Multi-Way 18 22nd June 2003 05:29 AM
Page generated in 0.08817 seconds (68.14% PHP - 31.86% MySQL) with 10 queries
