Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th January 2007, 11:39 AM   #1
diegot's Avatar
Default Eagle and tubes.lbr Help!
I'm using Eagle and the tubes library to draw a PCB for a tube amplifer. I use this program for a long time but when a add a tube in the schematic the heaters pins do not appear. How do I put them in the schematic?
Thanks for the help.
Old 10th January 2007, 11:55 AM   #2
pinkmouse's Avatar
If the library is set up properly you should be able to use the Invoke command, (the button with the four logic gates and cursor arrow on it). Click invoke, then click on the valve that you want to add the heater for, click ok, then place it where required.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 10th January 2007, 11:58 AM   #3
diegot's Avatar
Thank you pinkmouse. Worked!
Old 10th January 2007, 12:01 PM   #4
pinkmouse's Avatar
Good!
Just a quick point, measure your valve sockets to make sure they match the footprints, this has caught me out before.
Al
Old 10th January 2007, 12:32 PM   #5
diegot's Avatar
I thought about this yet, but I don't have the sockets in hand right now. I'll make a proto PCB until the sockets don't arrive, if I had any problem with them, I correct the PCB.
Thanks for point.
Old 10th January 2007, 01:16 PM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
Cool, been trying to figure out how to get lm3875 chips into an actual circuit
Using Eagle for Tubes designs alexmoose Tubes / Valves 3 30th September 2006 02:02 AM
eagle with tubes ? firefart_1st Tubes / Valves 6 25th June 2006 07:13 PM
Looking for Eagle CAD - Trade for tubes ALBQ Swap Meet 2 1st November 2004 12:15 PM
Eagle / .lbr tobias_svensk Parts 0 25th June 2004 05:11 AM
How do you do this in Eagle CAD? djnigma Everything Else 3 10th October 2002 05:23 PM
Page generated in 0.08029 seconds (70.62% PHP - 29.38% MySQL) with 10 queries
