Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What would you recommend as a replacement for NE5534N in a preamp?
Old 8th January 2007, 06:28 AM   #1
Hastur is offline Hastur  United States
Default What would you recommend as a replacement for NE5534N in a preamp?
See question above, would like to upgrade an existing preamp. Am thinking about either OPA2134 or OPA2604 since I have good stock of both. What else would you recommend, and would you recommend one over the other?
Old 8th January 2007, 08:14 AM   #2
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
NE5534A is a single amplifier.
The devices you mentioned are dual amplifiers. They won´t work.
So look for OPA134, OPA604 or OP176. But circuits using 5524 at low gains also contains 22pF compensation capacitors.
Analog Devices mention the OP176 as an upgrade for the 5534. According to the datasheet the capacitor won´t harm in most cases. But ADI recommend to remove the 22pF.
Old 8th January 2007, 07:29 PM   #3
nuvistor is offline nuvistor  United States
nuvistor's Avatar
OPA134 pin 5 and OPA604 pin 8 are open (no internal connection) so the 5534 compensation capacitor should not cause problems. You could also build dual-to-single adapters to use your OPA2134, OPA2604 but it's probably more trouble than it's worth.
Old 8th January 2007, 08:59 PM   #4
God I feel dumb, I also have a good supply of OPA134's, not quite enough, but will only have to buy a few. I think that's the way I'll go, thanks.
Old 9th January 2007, 12:43 PM   #5
sigurd is offline sigurd  Belgium
hallo Hastur,
very good for replacing the opamp NE5534 is OP27 or
OPA-134 AP. The OPA 2134 is a double of the OPA-134.
You can find them in : www.selectronic.fr
Succes. Grtz, sigurd.
Old 9th January 2007, 01:06 PM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Hastur, how many OPA134 do you need? I have 3 pieces I can send you no charge.
Old 9th January 2007, 08:30 PM   #7
Thanks for the offer, I only need 2 more. I'll send you an email with my address.
Old 26th January 2007, 08:03 PM   #8
jblmar is offline jblmar  United States
Default Wher to buy?
Anyone know where I can get the NE 5534H? I need a few for my Sound Technology ST 1701A.
Ron
Old 26th January 2007, 08:07 PM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
Thats not a Q I was expecting from the heart of the U S and A (Borrat term).
I saw my 4 opa2227 samples landed today in JHB, should mean delivery by monday... allready laid out PCB for the parallel circuit in the datasheet... It will be a headphone amp for an old friend...
What would you recommend as a replacement for NE5534N in a preamp?Hide this!Advertise here!
Recommend a Good Preamp for Pass Labs Amps misterdoggy Pass Labs 4 20th January 2007 05:43 PM
please recommend replacement transistors miekedmr Solid State 2 6th June 2005 07:54 AM
Can anyone recognise these transistors and recommend a replacement? ThaFresh Parts 6 8th January 2005 12:41 AM
recommend glue for dustcap replacement with ceramic cones Dan337 Multi-Way 2 23rd January 2004 09:46 PM
Can someone please recommend a preamp design for my bass wnichol Car Audio 2 11th May 2003 06:42 PM
Copyright ©1999-2017 diyAudio
