Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th January 2007, 01:01 AM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Angry Can't Regulate, Help!
Hi all.
I've built a dual rail supply, with a pair if 22.6volt rails. One plus one minus both need to be regulated to 15volts. I can't get the negative reg to work.
Un-regulated I have 22.6 volts either side of earth, the 7815 pos regulator gives +15 volts. The TS7915 won't work. Both regs are TO220 style cases and logic states it should work. Both centre pin 2(and tag) is 0 volts, both pin 1 in and pin 3 out. Both regs are from Maplin Electronics(UK) and I'm on my second negative reg. Take the regs out and I get + - 22.6 volts, dual rail to where pin 1 should be, 0volts where pin 2 should be?????
Help!!! Please
cheers mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 7th January 2007, 01:09 AM   #2
darkfenriz's Avatar
Add a 4.7k resistor from negative reg's output to ground.
Old 7th January 2007, 01:32 AM   #3
jnmar is offline jnmar  Portugal
Hi Mike.
You are not making the right connections on the 7915 they don't have the same pinout that the 7815.
Old 7th January 2007, 01:33 AM   #4
mikee55's Avatar
Default Hello there
The regulator cooks as soon as I apply power! Can you please explain why you'd add this resistor?,is this a load?
cheers Mike
Old 7th January 2007, 01:41 AM   #5
mikee55's Avatar
Default jnmar
I connect meter leads one to tab, the other to centre pin in cotinuity check. Meter says tab connects to centre pin. Looking above left pin in centre ov right pin out????
cheers mike
Old 7th January 2007, 02:13 AM   #6
mikee55's Avatar
Default Thanks for your help
Cheers guys, been and re-wired it to see if it was too late and the thing was dead.I got a reading of minus 4 volts then nothing.
The case was too hot to handle. I guess Maplin Electronics need a telling off. It should state that although its a TO 220 style case, its pins are not the same. Don't know if you're aware of Maplin ,but they've gone down hill over the past few years.
I will be complaining.
Many thanks for your help.
Cheers Mike
Old 7th January 2007, 04:22 AM   #7
radtech is offline radtech  United States
Default Re: Thanks for your help
I wouldn't exactly blame Maplin, it's pretty much common knowledge in the electronics field that 79xx series have a different pinout than 78xx. Generally if the manufacturer doesn't package documentation with the parts, the supplier isn't going to put it them in there either. They do however usually supply them on their websites, and leave it up to you to look them up. Here's a link to them:
TS7900 series docs (PDF) from Maplin site
Old 7th January 2007, 12:24 PM   #8
mikee55's Avatar
Default Didn't have PC available at the time
but had a catalogue to hand. I was not aware that the pos and neg regulators had different pinouts. It seems logical to me to give them identical pin outs or to state in print if they have different pin outs.
Frustrated Mike
how to voltage regulate space2000 Solid State 4 12th April 2008 10:02 AM
CDP tweaking - which IC to regulate? mr_push_pull Digital Source 1 18th November 2007 02:36 PM
To regulate or not to regulate duderduderini Tubes / Valves 3 24th October 2007 12:35 AM
To regulate or not? Ryssen Tubes / Valves 4 3rd April 2004 02:11 AM
Whats the best way to regulate a PS down? downhere Solid State 5 2nd December 2001 02:33 PM
Page generated in 0.09795 seconds (74.90% PHP - 25.10% MySQL) with 11 queries
