Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Looks like a transformer, but..
Old 3rd January 2007, 06:45 PM   #1
CarlyBoy is offline CarlyBoy  Canada
Default Looks like a transformer, but..
Hey all,
I might be an idiot. Here's the situation:
Taking stock of my transformers. Have an unusual one. One side black-white-black leads are connected. Very low resistance between the black leads (.3 ohm). Black leads are huge solid wire, looks like 14 AWG. White wire is just as thick but stranded. White-black resistance is 0.2 ohm
Other side three leads: green, green/beige, beige. Green/beige is CT because resitance is less between it and each of the others. (Curiously the beige wire has much less insulation and is thinner.)
Ignoring the fact I've not encountered more than two leads on a primary, I connected the AC to the black leads. Bringing up the voltage on the variac slowly causes the current draw to skyrocket past about 50V input.
Before I heave it into the bin, any idea what I've got here? Thanks..
Old 3rd January 2007, 09:18 PM   #2
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
The thick leads is never the primary. It's always the thin leads.
Old 3rd January 2007, 11:23 PM   #3
ak_47_boy is offline ak_47_boy  Canada
What about step up transformers?
Old 3rd January 2007, 11:45 PM   #4
AndrewT is online now AndrewT  Scotland
could this be some kind of audio transformer rather than mains power?
regards Andrew T.
Old 4th January 2007, 03:02 AM   #5
ReidK is offline ReidK  United States
Yeah, it sounds like somebody has never worked on a tube amp.
Reid
Old 4th January 2007, 03:05 AM   #6
DCPreamp is offline DCPreamp  United States
DCPreamp's Avatar
How about pictures?
Common-mode inductor?
Switching transformer?
Auto-former?
Buck-boost transformer?
Need more information to be of much help.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Old 4th January 2007, 02:54 PM   #7
Not an output transformer. Here's a pic:
Old 4th January 2007, 03:08 PM   #8
On Hiatus
SY's Avatar
Maybe. Maybe not. What's the exact resistance between green-beige and green? Between green-beige and beige? And green and beige?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th January 2007, 03:10 PM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
Hi
Have you tried to connect your variac on the beige (primary?) side.
LV
Old 4th January 2007, 03:44 PM   #10
edl is offline edl  Hungary
edl's Avatar
Maybe a transformer of a PC-UPS?
Looks like a transformer, but..Hide this!Advertise here!
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 10:35 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 06:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
