| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
HEY !!!! Good news guys ! You were right v-bro the problem was with that varnish on wires !
But now I'm wondering how to remove the varnish from bigger coils that are made of multiple wires. It doen't work with my solder iron. Maybe because it's a 15Watt should I buy a 25 watt ? Thanks, REALFLEO |
#12 |
I use a 60 watt with a 2-3mm flat tip - a bit hot for small parts but very good fore the heavy stuff
#13 |
Speakerholic
You can also scrape the enamel off with a knife.
#14 |
I overlooked in the beginning that it was litz wire inductors
Its clear by now that its not well suited fore beginners Even if it seeems like working ok, it could easily lead to malfunktion if only some of the wires have proper connection
#15 |
You can try Micro Jet Torch from Canadian Tire.
#16 | ||
They work like a charm, makes even the largest objects easy to solder and it is instantly hot...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#17 |
Ok I got it !
I'll go buy that jet burner ! Thanks everybody for you help. REALFLEO |
| heathkit crossover xo-1 / x0-1 problem | SOFIA1999 | Parts | 0 | 12th November 2008 04:53 PM |
| crossover problem(135 kep +XT19td) | bartekdg | Multi-Way | 0 | 25th October 2007 02:33 PM |
| Thermal Conductivity of Kapton Compared To Aluminum? | kelticwizard | Everything Else | 7 | 20th June 2007 05:23 AM |
| conductivity of hot glue? | Dominick22 | Chip Amps | 4 | 20th June 2006 04:18 AM |
| Crossover problem | Soldering Iron | Subwoofers | 2 | 6th January 2005 01:02 PM |
| Page generated in 0.10949 seconds (64.80% PHP - 35.20% MySQL) with 10 queries |
