Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need help locating a jog switch
Old 29th December 2006, 09:15 PM   #1
jc2 is offline jc2
Default Need help locating a jog switch
I'm having a hard time locating a part I need for a new project. What I'm looking for is a rotary switch that if you turn the shaft clockwise 30 or so degrees it closes a contact, if you turn the shaft counterclockwise it closes a second contact. The switch should return the shaft to the center once it is released. Like a jog dial on some VCRs.
Ideally the switch would have a 1/4" shaft, but I could deal with slightly larger or smaller.
Thanks in advance for any help.
J
Need help locating a jog switchHide this!Advertise here!
Locating transistors Canefire Solid State 10 29th December 2006 03:30 PM
Need Help Locating a Schematic! schwarcw Digital Source 3 16th November 2006 08:23 AM
Help locating some parts. Destroyer OS Parts 11 6th May 2006 07:39 PM
Need help locating a resistor Yukonsc Parts 4 18th November 2005 10:41 PM
Copyright ©1999-2017 diyAudio
