Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th December 2006, 11:04 PM   #1
Question contact cleaner
i have contact cleaner wondering if its safe to use on potentiometers to clean them. it says safe on plastics and metals. also says can be used on pcbs. also removes dust, oxidation, dirt, etc. i bought it from radioshack.
someone please help me out!!
Old 29th December 2006, 05:55 PM   #2
sbrads is offline sbrads  United Kingdom
It'll be safe but whether it's any good I don't know. It will probably work but what you tend to find is that some makes (don't me ask which) have a shorter period of effectiveness, i.e. the noises return after a week or two.
Old 29th December 2006, 10:35 PM   #3
Geoff H is offline Geoff H  Australia
Potentiometers need a bit of lubricant. In Australia we have a product called Inox. It's better than WD40 in many respects. A squirt of either will keep pots noiseless longer.
Geoff.
Old 29th December 2006, 10:54 PM   #4
v-bro is offline v-bro  Netherlands
v-bro's Avatar
At the repair department where I work we use two stage contact cleaner, one can for the cleaning the other for durable maintenance, works quite well for a long time...
First use Kontakt 60, after that use Kontakt2000 gold:
http://www.ts-audio.de/tsshop2/WGS/6...che_Sprays.htm
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 29th December 2006, 10:58 PM   #5
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
We also use a two step process. Caig D5 to clean, then Caig MCL to lubricate.
Old 30th December 2006, 03:49 AM   #6
unclejed613's Avatar
Default deoxit
i've been using wd-40 for years, then began using remington oil with teflon, but recently discovered a product called De-Oxit which works extremely well.
wd-40 was good for flushing dirt out, but the lubricating film would evaporate within a week or so. the rem oil would lubricate better, but the teflon solids could eventually pile up on pot wipers causing them to get intermittant again, deoxit seems to work better, and is supposed to eliminate oxidation on contacts.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 30th December 2006, 04:06 AM   #7
Proud Union Member
imix500's Avatar
unclejed613, yup that's what we use on everything that's not gold plated. If you're using the 100% (D100) metered spray you're ok, but the 5% (D5) liquid does not have much lubricant in it, that's where the MCL is used next as that's all it is.
Old 30th December 2006, 07:32 AM   #8
v-bro's Avatar
Another thing that is very important is never to use too much, access oil attracts more dust and will make the contacts dirty again quick...I know it's tempting to get rid of that tedious crackling by drowning the potmeter in oil....I would advise to (if the potmeter allows this) even wipe off all access oil....or start by adding only just enough....
Old 30th December 2006, 12:21 PM   #9
When cleaning pots and faders, it there ever too much of the cleaner? Also, would using cleaner without lube expose one to more crud than before?
Old 30th December 2006, 12:50 PM   #10
v-bro's Avatar
If the pot is worn it won't help, but if it's really dirty you can clean with cleaning spray and add a little lube spray when it has dried...
best CD/DVD/CD-ROM cleaner jives11 Everything Else 3 6th June 2007 05:52 AM
Best pot cleaner (available in the UK) cpemma Parts 4 21st July 2006 04:23 PM
DIY Cleaner $$$ ? LHMAudio Analogue Source 21 12th June 2006 03:39 PM
Cheap Contact Cleaner mrfeedback Everything Else 0 28th May 2003 05:21 AM
Page generated in 0.10535 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
