Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th December 2006, 08:14 PM   #1
Onvinyl's Avatar
Default What do I see on my scope?
While checking an amp, feeding it with a pure sine wave, I can see that sine wave in ok shape but painted in a thick line. What should that tell me?
Without a signal, the amp shows only background noise,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 28th December 2006, 08:23 PM   #2
pinkmouse's Avatar
Oscillation.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th December 2006, 09:21 PM   #3
Onvinyl's Avatar
Argh, always my darkest dreams come true
Rüdiger
Old 28th December 2006, 10:39 PM   #4
pinkmouse's Avatar
It may not be as bad as you fear. That kind of problem with low level oscillation may well be solvable by lead dress or better PSU decoupling.
Al
Old 28th December 2006, 10:40 PM   #5
Harmonics?
Poor stereo mix? Switch to mono! Perfect.
Old 28th December 2006, 10:47 PM   #6
pinkmouse's Avatar
Originally posted by davidlzimmer
Harmonics?
Possibly. Crank up the time base on the scope and see if you can resolve a waveform. If it's harmonics then it will likely not be that much higher in frequency. Harmonics will also change with the input frequency, wheras oscillation is unlikely to. However, I personally have never had a problem like this due to harmonic distortion, but there's always a first time!
Al
Old 28th December 2006, 11:46 PM   #7
SY's Avatar
Depending on the test frequency, it can also be hum/ripple. Try synching to the line and play with the trigger level to see if there's some low frequency stuff in there.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th December 2006, 04:16 AM   #8
I_Forgot's Avatar
It may also be a crappy scope. A lot of old scopes get fuzzy as the capacitors in their power supplies go bad. A good scope will display a thin, sharply focused line. Does the scope have a 1 kHz square wave calibration signal you can look at?
I_F
Old 29th December 2006, 04:43 AM   #9
Pano is offline Pano  United States
Pano's Avatar
If it's a Class-D amp, it the switching RF!
Take the Speaker Voltage Test!
Old 29th December 2006, 05:41 AM   #10
most likely a trick question.
easy - somethings wrong somewhere
sorry, hard to refrain with question like these....
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 09:59 PM
My first scope! bigwill Equipment & Tools 3 7th July 2006 05:10 AM
can your 'scope do this? jackinnj Equipment & Tools 6 30th June 2006 02:21 PM
10 Mhz Scope enough ?? Henrik Juhl Equipment & Tools 24 20th October 2004 06:05 AM
Page generated in 0.10519 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
