| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have done a search on the forum but have not come up with anything.
I am looking for a company/manufacturer in the US or Europe who can make me a front plate for my amp. It needs to be laser or water cut, engraved and anodised. I looked at Frontpanel Express (Seattle, WA), but they only do up to 4mm thick aluminium and I need 10mm. Hope someone can point me in the right direction - thanks |
#2 |
If my machinist's interested, I could work up a quote for you.
I'm curious though, why do you say it must be laser or water cut rather than milled? se |
#3 |
no reason other than I've been told the finish is better and its usually lower cost.
rgds |
#4 | |
Do you have mechanical drawings ready? Also, what sort of finish were you wanting? Grained? Bead blasted? A combination? What color anodizing? se |
#5 |
http://www.schaeffer-ag.de/index.php...id=205&lang=en
they will let you download a program and then you upload the art to them and they send it to you. they are in germany maybe you could also use e-machine shop as well http://www.emachineshop.com/ |
#6 |
Gentlemen, thanks for the input
I've downloaded the design tools from both thyese sites and will see what the costs are when I submit them for quotes - I'll post the results on the forum. |
| Front Panel / Enclosure Help | tumler | Parts | 8 | 7th August 2007 08:41 AM |
| UK Front Panel metal work | cliffforrest | Everything Else | 7 | 22nd July 2007 08:07 PM |
| DIY Front Panel !! | udip | Solid State | 12 | 16th January 2005 06:37 AM |
| Front Panel Artwork Software | johnnyx | Everything Else | 25 | 1st May 2004 02:30 PM |
| Aluminium for front panel | jouch | Solid State | 7 | 15th March 2001 10:51 PM |
| Page generated in 0.09166 seconds (73.41% PHP - 26.59% MySQL) with 10 queries |
