Some Heatsink Calculations... Some Heatsink Calculations... - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st December 2002, 12:52 AM   #1
dkemppai is offline dkemppai  United States
Default Some Heatsink Calculations...
Oh boy, Oh boy! I love E-Bay!
I ran into some heatsinks on ebay the other day, and snapped a couple of them up. Now that I have them, and before I even dream about cutting them I need to figure out what they can dissipate. (Degrees/Watt per inch, that is)
It's so cool! Pun intended, the UPS guy left them between my screen door and front door... ...they almost knocked my wife off the porch when she came home!
Anyway, The heatsinks are 25 inch long chunks, of 11 inch wide by 3/8inch base. Each has 32 fins that are 1 inch high. Anyone have a feel, or have a way to calculate the rough thermal dissipation per inch of something like this?
AAVID does not have this particular extrusion avaliable on their web site. I do not know the MFR for this part. (Similar part number on AAVID shows around a .4C/W at 10 inch lengths no forced air. I will try to get a picture, if this may help.
-Dan
Old 13th January 2003, 02:27 AM   #2
This is the extrusion... ...copied this picture from ebay, from the guy I bought it from. (He currenty has more)
So no takers on how to estimate the thermal ratings of this thing?
-Dan
Old 13th January 2003, 03:28 AM   #3
grimberg is offline grimberg  United States
grimberg's Avatar
Dan,
Have you looked at R-Theta's manual? It has extensive coverage of thermal resistance calculation. To find it, go to www.r-theta.com, select EXTRUSION on the left nav bar and in the next page click on DOWNLOAD CATALOG. The download is divided in three parts, and the first one contains all the theory and formulas.
Old 22nd January 2003, 05:39 AM   #4
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Let me tell you what to do.
Grease and clamp a bunch of metal cased resistors to the flat side. Do some ohms law calcs to find the voltage and resistance for the wattage you're trying to dissapate. Power it up, let it run for an hour and measure the temp in a few places. By playing with a variac, and thermometer for a while, you can get some real reliable data on those puppies. I almost bid on that same sink BTW.
If you read r-theta's white papers on themal resistance calcs, you can get a feel for what cutting them up will do.
Old 22nd January 2003, 06:01 PM   #5
awhiteguy is offline awhiteguy
Default Elliott Sound Products
You can get a pretty good estimate with this spreadsheet:
http://sound.westhost.com/download.htm#hsink
-awhiteguy
Old 22nd January 2003, 11:00 PM   #6
This is what I plan on doing, except that I don't want to spend much for resistors. (Althoug, I am considering building some large 4 ohm test loads... ...might be a good time to start that project up again )
I'll probably use a couple of old transistors, and build a regulator to maintain power disipation.
The problem, is that I would like to have a good feel what the disipation will be after I cut them, long before I actually make the cuts. I'll keep browsing through the web pages... ...There should be something similar on the web!
-Dan
Old 22nd January 2003, 11:50 PM   #7
psychokids is offline psychokids
hello, i plugged the values for your heatsink into rod elliot's heatsink calculator, and it said about .2 C/W bare aluminum, and .083 C/W if you got them anodised black. however, id say that actual measurments using resistors and a thermometer would be more accurate than any equation could tell you. i have a couple heatsinks that im going to measure pretty soon, and i got a few LM35 TO220 thermometers to bolt to them. should be pretty accurate. good luck with the project.
-Chris
Old 23rd January 2003, 07:25 AM   #8
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
If you cut this huge heatsink into normal pieces I think the thermal resistance is not very low beacuse of it's the rather short fins. Good thing though is that the thick base.
Have you checked http://www.fischerelektronik.de/
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 23rd January 2003, 10:04 PM   #9
-Chris
Chris,
You'll have to let me know how the LM35's work out. I have a couple here, but have not used them. I use a non contact digital thermometer for most of my measurements. Surface emmisivity may affect the readings, but I think it gets me within a few degrees.
This project has been pushed way back on the list. House projects, and an article I'm trying to get published from an even older project! There's never enough time.
Peranders,
I think that they should be fine for what I want to use them for. I have some similar heatsink, a few more fins, and a little wider. I'm running an amplifier on that, and it seems to stay pretty cool. I've never done the actual measurements or calculations on that one eithor. I'll just use some schlep math, and figure a similar size chunk of aluminum... ...in reality, My amplifiers don't really ever get run very hard anyway. (It's just that lots and lots of heatsink looks neat )
-Dan
Some Heatsink Calculations...Hide this!Advertise here!
Heatsink calculations TroelsM Parts 28 5th August 2006 09:53 PM
Can somebody please check my bias/heatsink calculations? spence Solid State 10 31st March 2005 08:29 PM
calculations lXxAndyxXl Multi-Way 8 19th October 2004 04:53 PM
heatsink calculations metebalci Parts 4 23rd July 2004 02:35 PM
THD calculations tiroth Solid State 11 24th January 2002 11:05 AM
Copyright ©1999-2017 diyAudio
