Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Where should I get Wima MKP2 and FKP3 caps? (or alternatives)
Old 17th December 2006, 01:24 PM   #1
Peteruk is offline Peteruk  United Kingdom
Send a message via MSN to Peteruk
Question Where should I get Wima MKP2 and FKP3 caps? (or alternatives)
Hey all,
Ive decided to replace the output capacitors in my 41hz Amp4 kit with Wima Polypropylene ones, specifically MKP2 and FKP3 types (small size, RM5 and RM7.5), with values ranging from 0.1uf to 0.22uf.
However, Ive checked some of my usual suppliers, but they either dont stock these, or are sold out.
Does anyone have any suggestions as to where to look for these?
Of course, Id be very interested in knowing any as-good or better alternatives.
Thanks,
Peter.
Old 17th December 2006, 09:03 PM   #2
AMV8 is offline AMV8  United Kingdom
Hi
LCR polypropylene capacitors from Maplin are the best and most cost effective I have found. They are available in values up to 10uf at good prices. You can spend much more but I doubt that you will find better caps than LCR.
Don
Old 3rd August 2007, 07:33 AM   #3
ticktock is offline ticktock  Scotland
ticktock's Avatar
Hello,
the Wima FKP3 are one of the sonically best available.
Search google for them, they are still made.
Years ago I ordered several at buerklin (sold out), but ar still
available at some others.
They sound better than a simple MKP because of their heavy
construction with solid metal foils.
I use them in the RIAA-section as filtering caps
thanks
Blaue Leuchtdioden machen bld. (hb)
sent from NSA monitored device
Old 3rd August 2007, 08:41 AM   #4
ashok is offline ashok
ashok's Avatar
Are Evox-Rifa polyprops no good ?
AM
Old 4th August 2007, 11:43 AM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
RS Components UK.
Old 5th August 2007, 03:30 AM   #6
ticktock's Avatar
@ Nordic: thank you !!
@ askok: FKP & KPs sound (& measure) better than MKPs
one difference: MKPs have only metalised foils, KPs have solid
metal (most aluminium) film/foil construction.
Some audiophile types use zink or copper, but these are much
are expensive and larger as well.
thanks
Old 23rd February 2011, 04:09 PM   #7
MCampbell is offline MCampbell  United Kingdom
Also Audiocap.co.uk for higher voltage FKP2 series (250V to 1000V) which RS don't stock.
Old 23rd February 2011, 05:03 PM   #8
Mooly's Avatar
I hope Peter has got them by now... it's over 4 years ago
Old 24th February 2011, 10:50 AM   #9
You can never be too sure - what with current lead-times ;-)
Where should I get Wima MKP2 and FKP3 caps? (or alternatives)Hide this!Advertise here!
Wima MKA caps Calamaro Parts 0 6th April 2009 11:11 AM
WIMA FKP3 PP-Film/Foil Capacitor -> where to buy ? Dirk67 Parts 17 10th January 2008 10:08 AM
FS BB OPA660AP, WIMA caps, ROE Caps and other Andypairo Swap Meet 10 13th August 2005 03:46 AM
where I can buy wima mkp2 patriz Parts 4 8th April 2003 07:38 AM
Wima MKP 10 caps Ilianh Swap Meet 5 12th March 2003 10:29 PM
Copyright ©1999-2017 diyAudio
