| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have some cell phone batteries I plan on using with headphone amplifiers. These have 2 positive contacts, one goes straight to the battery and the other one is the output from the small circuit board.
My question is which one is for charging and which one if for the output? I've searched the net for almost an hour now and can't seem to find any info. |
#3 |
Unless you know what you are doing and know that you aren't going to do anything that creates an unsafe situation I wouldn't recommend bypassing the monitoring circuitry.
One three pin cell phone batteries you generally have ground, the positive battery voltage, and the 3rd is either some sort of serial communication, or more likely a thermistor connected to ground that is used for identification and as a temperature monitor. |
#4 |
If those are Li-ion batteries, then DO NOT bypass the safety cutoff circuit! If discharged too far Li-ions can go into destructive self-discharge.
Have you considered after-market Ipod replacement batteries? They're way cheaper that cell phone batteries, and they have a nice wire with a plug on the end, instead of flat contacts. |
| Horn for Cell phone | alexmoose | Multi-Way | 1 | 9th August 2008 11:20 PM |
| how does a cell phone get it right to transmit over 7km | jacquesl | Everything Else | 18 | 8th December 2006 12:18 PM |
| Need to rig something to record cell phone... | LMJ | Everything Else | 5 | 22nd September 2005 10:38 PM |
| Mobile/Cell Phone EMI | Con | Multi-Way | 3 | 29th August 2004 01:21 PM |
| Page generated in 0.09592 seconds (68.00% PHP - 32.00% MySQL) with 10 queries |
