Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd July 2011, 01:33 PM   #11
DF96 is offline DF96  England
"mf" is old American for microfarads? "15mF" (at 63V) is reasonably unambiguous, as 15uF would be too small for a smoother at low voltage but 15000uF would be plausible. Strictly speaking "15mf" means 1.5x10^-17, as it combines two prefixes with no units.
Old 2nd July 2011, 04:35 PM   #12
mf is gobble de gook as you have pointed out.
MF is almost as bad in that it is (almost) incomprehensible.
regards Andrew T.
Old 2nd July 2011, 06:44 PM   #13
15MF would be a very big capacitor!!
I don't know if you are old enough to remember the newspaper adverts for early tranny radios "2 bands, 5 transistors, 400MW output"!
Old 7th July 2011, 12:31 PM   #14
Rogelio is offline Rogelio  Philippines
I think bulging of capacitor was due heat created by voltage exceeding the working voltage of capacitor or high frequency current filtered by capacitor for a long period that result "oil" inside the capacitor to expand.
Old 7th July 2011, 01:42 PM   #15
No, unlikely on both counts. Andrew tells us that he was within the voltage rating. It was being used as a smoother so there would not be much high frequency current, but could be lots of low frequency current.
Pressure in an electrolytic cap is caused by gas, not the "oil" expanding.
Old 8th July 2011, 02:53 AM   #16
If you noticed capacitor w/ bulging problem mostly happen with PWM or Power Supplies and motherboard connected to the pwm psu. This PWM circuit have 20khz high freq oscillator.
Analog Power Supply ( half wave 60 hz and 120 hz. ) also have this problem but it was due to defective regulator circuit or over voltage. Unlike with PC PSU having more bulging capacitor problem than analog psu.
"oil" or electrolyte inside the heated capacitor produced hydrogen gas.
Analogmetric - Another HK Dodgy Dealer poynton Parts 16 25th June 2011 05:48 PM
CD With dodgy low frequencies ... mart34 Multi-Way 5 12th July 2009 04:01 AM
dodgy amp power supply obaka-san Parts 1 9th January 2008 09:12 AM
'Dodgy' tap water ash_dac The Lounge 14 8th March 2006 02:18 PM
Dodgy amp needs repair sbattersby 115 Instruments and Amps 13 29th April 2005 09:33 AM
Page generated in 0.08771 seconds (78.40% PHP - 21.60% MySQL) with 10 queries
