Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Some help needed re: old capacitors...
Old 14th December 2006, 08:21 AM   #1
adhoc is offline adhoc  Australia
adhoc's Avatar
Question Some help needed re: old capacitors...
G'day all,
Once again I have some mystery caps I wish to identify!
These 2 capacitors come from a 30 year old B&K 747 tube tester, and I am replacing them with newer examples. However, I wish to maintain their 'type' - i.e. electrolytics replace electrolytics, plastic films replace plastic films, etc - so identifying their type correctly is of paramount importance to me.
LEFT: marked 0.047uF on schematic, I think it's a polyester.
RIGHT: marked 0.01uF on schematic, I think it's a ceramic disc.
Also, are both caps P or NP? It is not clear from the schematic - I think that they're NP though.
Anyone?
jitter critter.
Old 14th December 2006, 09:57 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
the .47U can be replaced with a polypropylene cap just make sure to not go below the 250V rateing.
The ceramic should at least be replaced by a C0G or NP0 type ceramic, or silver mica if you can afford those. just check where you took it out what voltages are there... I thin kthe green dot at the top is a code for 500V
Some help needed re: old capacitors...Hide this!Advertise here!
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 01:38 PM
radial capacitors???-info needed moonshow Chip Amps 12 1st November 2004 11:12 PM
Capacitors for phono preamp needed maestro00 Parts 2 25th June 2004 02:49 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 10:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
Copyright ©1999-2017 diyAudio
