| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have modelled a RIAA preamp in circuitmaker which looks good in theory, and the curve matches very closely the output from the national semiconductor "example circuit" of the LM4562. which I moddeled along side it. my circuit is active rather than passive though and uses only one opamp per channel.
how do i even know the national one one is any good though. i would like a way to somehow check my simulation against a proper idealised RIAA curve. any help would be greatly appreciated! best regards Neutron7 |
#2 |
Banned
See Figure 3 and the text below it on this page for an example of using a Laplace controlled source to verify this. There are also some design equations and an example network there. That example assumes you're trying to match the Neumann time constant, so if you aren't, just remove the (s*3.18e-6+1) term in the numerator.
Also see Walt Jung's site here |
#3 |
Electrons are yellow and more is better!
I have made a couple of Excel spreadsheets which may be to some help for you.
They are a bit too large (>100k), so send me a message and I'll email them to you.
/Per-Anders (my first name) or P-A as my friends call me |
#4 | |
What constant? An SX-74 is second-order low-pass with -3dB at 50kHz. An SX-66 has its -3dB point at about 30kHz, forgot about the order.
bring back dynamic range |
#5 |
Account Disabled
An example of this:
#6 | |
Banned
#7 |
I ended up copying a table of RIAA values into excel and then comparing my results to them. then i made a graph.
The drop at the low end is because there is a rumble filter below 20hz. it actually gos down about 20db at 1 hz. I am just waiting for some capacitors from ebay to build it! and because there is a large value cap on such a sensitive circuit, i think i might have toi get some of those black gate NX for the rumble filter. theoretically the voltage on the cap would never be more than 5 volts but do you think it is safe to use a 6.3v blackgate there (because they are only $2.50 |
| Where should be fb compare to fs | ostie01 | Subwoofers | 8 | 9th May 2006 11:56 AM |
| RIAA preamp curve page? | Darren Nemeth | Analogue Source | 3 | 20th January 2005 07:54 PM |
| Rca Input - Riaa Curve | Caiofrv | Car Audio | 0 | 19th October 2004 03:57 PM |
| Compare with CRC or CLC | billy | Pass Labs | 1 | 30th May 2004 12:54 PM |
| compare the Boz & Bls | billy | Pass Labs | 1 | 9th February 2003 03:09 AM |
| Page generated in 0.11180 seconds (80.39% PHP - 19.61% MySQL) with 11 queries |
