| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 | |||||||
As for ferrite bead on the speaker cable, I assume I would be able to put this around the internal speaker cable runs instead of the run from the amp to the speaker (which is what i've heard people saying). Quote:
I did attempt some calculations to explain the rather large difference in DC offset between the two chips. The calculations seemed to suggest the... bias current (I think) on the chip with the higher DC offset was about twice that of the other chip. I don't quite know what bias current is yet, but might this mean that one chip would be drawing more power at idle than the other? (apologies for my non understanding & usual guessing) Quote:
[quote] You may want to try both. The cable shielding might come under scrutiny this way. Interference from that could be of a greater level than the hiss. Quote:
Hmm. I think maybe I should also probe the speaker outputs of my current integrated amp to see if this has the same sort display. EDIT: Oh, these is a slight difference between the two power supply boards by the way. One has Panasonic FC main filter caps, the other has...."R.M" caps. EDIT: I seem to be seeing the exact same wave pattern appearing on the output on my current integrated amp. |
#32 |
I managed to get a temperature probe to *just* reach the amp chip heatsinks. The 'hot' one is 43C, and the 'cold' one is 38C. I can't measure the regulator heatsinks as the probe lead doesn't reach. But by touch, it seems like the difference in temperature is probably about the same as with the chip's.
Perhaps I just shouldn't be worrying |
#33 |
Nothing useful to say other than I feel that such a difference is probably not a problem per se, but possibly a mismatch. For one thing, are your chips mounted identically in orientation, componentry, and the amount of thermal grease (not too much)? You mention different capacitors and to a small degree these may affect the level of the rails.
I would probe the components on the boards and compare the voltages between the two in an attempt to find a lead. |
| P3A oscillation | clive299087 | Solid State | 22 | 18th November 2006 11:58 PM |
| oscillation | merkur | Tubes / Valves | 28 | 10th May 2006 12:19 AM |
| CDP Oscillation | emmasdad | Digital Source | 0 | 4th January 2006 02:54 PM |
| Oscillation | udip | Solid State | 5 | 31st January 2005 05:43 PM |
| What is oscillation? | jnxw2 | Solid State | 10 | 18th May 2003 11:31 PM |
| Page generated in 0.08035 seconds (79.79% PHP - 20.21% MySQL) with 10 queries |
