Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Capacitor lifespan and audio quality
Old 20th September 2012, 12:39 PM   #31
fas42 is offline fas42  Australia
Banned
Originally Posted by Terry Given View Post
Frank, I wouldnt touch them with a bargepole. I just trawled through their website, and the amount of data they provide is negligible. OTTOMH their lifetime figures didnt look crash hot, and the lack of datasheets scares me.
Terry, did you check out Capacitor Distribution | Electronic Engineering Services - ICD Sales , plenty of data there? I note that they also have factories in Taiwan and Malaysia ...
Frank
Old 20th September 2012, 08:58 PM   #32
jackinnj is offline jackinnj  United States
jackinnj's Avatar
In the mail-bag from EDN this afternoon -- note that you might have to close the commercial trailer which appears at the beginning:
Power Tip #50: Avoid these common aluminum electrolytic capacitor pitfalls | EDN
Old 21st September 2012, 02:43 AM   #33
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Indianajo,
indeed. the temperature rating alone isnt enough to base a purchasing decision upon. And although it too is necessary, I maintain that high rated lifetime isnt enough either.
there are a lot of really crappy cap manufacturers. there are very few that make excellent quality caps.
Nippon Chemicon, Nichicon, Rubycon, Panasonic
I have yet to find a better cap than a Rubycon ZLH. any datasheet that purports to do better is probably lying.
yep to all the above -- all else being equal the 105C is usually better if you have to guess about it. - RNM
Old 21st September 2012, 04:07 AM   #34
Terry Given is offline Terry Given  New Zealand
Frank,
yeah I did, and still wasnt happy with the datasheets. One ROT I have found very useful is this: If it isn't spec'd in the datasheet, its either lousy or not controlled.
Mostly my argument comes down to this: any arbitrary cap vendor is going to have to work very, very hard indeed to convince me to not buy the very best (as listed above). why would I want to try something new? The best possible outcome is that they are as good as the top manufacturers. Every other outcome is worse than this, and its a crapshoot - with the results only able to be determined some years down the track.
those Samxon caps I mentioned? the SMPS manufacturer changed from Rubycon to Samxon, and 6 months later the audio OEM started seeing problems - by the time I got involved it was >> 10,000 faulty units.
and for DIY purposes, the total amount of money saved is literally a few dollars. Do what you want, but dont be surprised if (when) you have problems with el-cheapo caps. And I'll laugh at you and say "I told you so"
Old 21st September 2012, 04:24 AM   #35
Banned
Frank,
Fair enough ... let those dogs keepa sleepin' ...
And, hope your wife is in better shape ...
BTW, my wife comes from across the ditch, used to live in Mount Roskill ...
Frank
Old 21st September 2012, 04:33 AM   #36
Frank,
yeah thats exactly it. I had a similar discussion years back with a vendor who wanted us to switch to their parts. He said they could match (whomever)s price. I pointed out that there is no net benefit to us, and that we have to do a bunch of work to approve new vendor - so he'd have to do a lot better than just match their price. he left sans order.
thanks.
My auntie used to live directly across the road from the Mt Roskill fire station when I was a child. it used to be the highlight of a trip when the fire engines came racing out. Ah the joy of simple pleasures.
Old 21st September 2012, 12:14 PM   #37
jackinnj's Avatar
Our new-ish refrigerator failed for the same reason! This very expensive unit had 2 SMPS supplies. The service folks couldn't understand that failed caps caused the first SMPS to fail, causing the fan to fail etc., etc. There they were, sitting on the PCB bulging as if they wanted to give birth.
For want of a couple bucks they wound up paying $800 as the unit was under warranty.
Old 21st September 2012, 05:53 PM   #38
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
SMPS in refrigerators?! Gettin' too fancy for me! I had a digital TV converter box fail on me; turned out it was just a failed electrolytic in the switching supply. Didn't even need to break out any test equipment to diagnose and fix that one, and saved me having to buy a new unit.
There's gotta be a better way than electrolytics for commodity switchers...
Old 21st September 2012, 06:31 PM   #39
jackinnj's Avatar
The EDN article referred to above states that the 23,000 hour life of a LED lamp is completely bogus since the electrolytic capacitors won't last more than a few thousand hours.
The "Kitchen Aid" used an SMPS to convert the line voltage to 3 phase in order to drive the motors more efficiently, or so one of the techs told me. The other SMPS powered the microcontrollers.
Old 21st September 2012, 11:12 PM   #40
Yeah, I could see a SM inverter/controller for efficient motors, especially variable speed.
Capacitor lifespan and audio qualityHide this!Advertise here!
Lifespan of capacitors GeeVee Parts 9 2nd February 2011 08:15 PM
Capacitor sound quality, silver mica in particular klitgt Parts 14 23rd September 2005 04:54 PM
Capacitor Quality and Placement Milzie Multi-Way 8 4th January 2003 01:27 AM
Capacitor Sound Quality fmak Solid State 17 27th June 2002 07:19 AM
Precision high quality Capacitor brands/sources jgwinner Parts 8 27th May 2002 03:26 PM
