Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
I tried toner transfer today...
Old 9th December 2006, 10:15 PM   #1
gmikol is offline gmikol  United States
Default I tried toner transfer today...
...and I had pretty good results.
Here's the top.
Old 9th December 2006, 10:16 PM   #2
Here's the bottom.
Old 9th December 2006, 10:19 PM   #3
I transfered one side. Drilled some alignment holes, and used it to align the other side. The registration wasn't perfect. But all I had was a wobbly 1/16" bit. I was waiting to order carbide bits until I saw how well it went.
The registration:
Old 9th December 2006, 10:23 PM   #4
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
sweet! what paper did you use?
Old 9th December 2006, 10:29 PM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I do both sides at the same time. Print them both out on the same piece of paper, about 2cm apart,then you can use a lightbox or window to align them perfectly before creasing the fold in the paper. Allow another couple of centimetres overlap of blank paper at the top and bottom, and you can stick them to the PCB with masking tape, then iron both sides. Works every time!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 9th December 2006, 11:02 PM   #6
Here's what I did...
Inspired by this thread from dfdye:
http://www.diyaudio.com/forums/showt...threadid=80165
I bought the laminator he mentions, the XRX-LM1910 from Staples. It's manufactured by Xerox, so you may be able to find it other places, as well. The manual packaged with the unit doesn't specify a max. thickness, but I found a manual from Xerox:
http://www.xerox-oa.com/lm1910-xrx.pdf
(Unfortunately, the link seems to be dead, now)
It listed the max. thickness of as 1/12"...perfect for 1/16" thickness boards. The laminator has different temperature settings for various pouch thicknesses, plus a "Foil" setting. In my experiments, the foil setting was the one that worked the best. The feed roller is pretty far into the housing, so the minimum dimension is about 2.5" to 3" You need to press pretty hard to get it to start feeding & not stall, but once it started, I never had a problem with slippage or stalling.
I tried a whole bunch of different media. Inkjet transparency, laser transparency, baking parchment (not wax paper!), synthetic parchment from a stationery store, and last, Pulsar Toner Transfer paper I got from a friend. The only thing I didn't try was inkjet photo glossy paper, because neither of us had any.
Everything was printed in a 10-year old HP LaserJet 4MV with genuine HP toner. The winner was the Pulsar paper, and second place was inkjet transparency. It was 3M type CG3460. There were no problems with it melting or shrinking & getting brittle in the printer or the laminator. But it did have problems with large copper pours near the edge of the board...more of the toner tended to pull off in these areas, but I'm not quite sure what exactly caused it. All of the other media gave very poor results.
I think you could use a humidifier or steamer to with the inkjet media. I think that the little bit of moisture will cause the gelatin to swell, and release from the backing a little bit. Then it could be rinsed off while the toner stays. Just an I idea, but I have neither a steamer nor a humidifier. Just don't get them fully wet!!! I tried that, and it made a huge mess.
I used 2-3 passes to do the toner transfer, but I only needed 1 pass for the Pulsar Green TRF foil to seal the toner. I didn't have a second board to compare TRF to no-TRF. But if you look at the "registration" picture above, I still got a tiny bit of pitting. I think a scrubbing with scotch-brite and tin-plating should alleviate any concerns about that.
I etched with a HCl - hydrogen peroxide mixture. 3% peroxide and 31.5% HCl mixed in a 2:1 ratio, acid added to peroxide and etched with gentle back-and-forth rocking.
This page has some info on the ideal ratio of HCl to peroxide:
http://www.dr-lex.34sp.com/info-stuf...rtransfer.html
I don't know if it's correct or not, but according to his calculations, I should be using a ratio of 8:3:1 peroxide:HCl:water. I thought 2:1 was close enough, and it worked in about 5 minutes, even on my cold garage floor.
About the board...the holes are 0.5mm, 0.7, 0.9 and 1.0, with 8,12,16,20,24 mil annular ring. The tracks are 4 mil line/4mil space at the top, and the 6/6, 8/8, 10/10, 15/15 and 20/20. The 8 mil are very good, and the 6 look OK, but the scan didn't capture it.
Anyway...I apologize for writing a book, but I just wanted to share my experiences. Thanks to the forum for helping me put all the pieces together.
--Greg
Old 9th December 2006, 11:04 PM   #7
I did it one side at a time because the Pulsar paper is so thick that light doesn't shine through very well. If I could get the transparency film working, then it would be a no-brainer.
What kind of paper are you using, pinkmouse?
--Greg
Old 9th December 2006, 11:17 PM   #8
pinkmouse's Avatar
Epson Glossy Photopaper,194g/m2, ref: S041140 with an HP laserjet 4000.
Old 10th December 2006, 04:58 AM   #9
head_spaz is offline head_spaz  United States
I use the Pulsar transfer paper and TRF too.
I get really good results, and Pulsar's TRF was a brilliant idea.
I found that applying 2 layers of the green TRF gets rid of the pitting.
Without TRF, the pitting is horrible, at least I've had trouble with it.
I use a Minolta/Konica Page-Pro 1350W laser printer @ 1200 x 1200.
I scale my artwork using Paint Shop Pro, and the printer prints the exact size... to less than .001" variation. (I've always hated HP software... their drivers suck!) Very happy with this printer.
The biggest problem I have is getting the heat right on my iron. Typically, it gets too hot and bubbles the toner. Then it smears and the resolution goes away. Maybe Santa will bring me a laminator for Christmas! (nerd!)
Writing is good exercize for the texticles!
Old 11th December 2006, 02:02 AM   #10
dfdye is offline dfdye  United States
dfdye's Avatar
Greg,
Those boards look quite nice. After seeing the final product I think I am sold. I'll have to pick one of these laminating machines up the next time I start prototyping boards. The pitting you commented on isn't any worse than the boards I typically make using an iron, and for a 1-off board it should be quite acceptable. I did notice that the thinner traces around your drill holes seemed a bit uneven, but overall the quality of the traces is very good. As far as toner transfer boards go, yours are right up there with the best results I have ever gotten myself. If this means I can easily avoid photoresists, this will be well worth the $80.
MANY thanks for sharing your results! I'm quite glad that someone followed up on testing this idea since I am a slacker and didn't ever follow through!
David
I tried toner transfer today...Hide this!Advertise here!
Toner transfer with a twist -- anyone tried this? rif Construction Tips 18 8th January 2018 06:09 PM
PCB: toner transfer using acetone? Limhes Parts 4 22nd February 2008 07:55 PM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
toner transfer method(my mistakes) rs1026 Everything Else 3 13th October 2004 01:37 AM
